HaHaHey Leif,
Looks like you're not the only guy delivering speakers with flip-flops....View attachment 57211.View attachment 57210
HaHaHey Leif,
Sorry it took so long for me to get back out. But we definitely have some good hours on everything now. It didn't take much to lock it in. How was late night listening session?I thought I had good sound until today.....A few minor tweaks by Leif and another giant leap forward for my system. This is going to be a late night for me. Good thing my wife is out of town.
Big thanks Leif!!!![]()
Rodney
I will be in Las Vegas tomorrow through Sunday. Coming in to see Fleetwood Mac for their Farewell Tour
Wow SteveRodney
Rodney,
I have been a fan of Center Stage footers since I was part of their beta test. BUT their insertion into my new system all at one time, with all new equipment and cabling has been a roller coaster of a ride that has taken 3 1/2 weeks to become listenale. Curious if you had the same scenario.
Holli82 truly amazing system. Just curious did you consider any other speakers before deciding on the ultra 9s?
I notice that your listening room dimensions are similar to mine. I have a constrained layer damped 16" thick walls with built-in activated carbon bass filtering, 12" 3000 PSI steel reinforced floor and less damped ceiling with side walls and ceiling heavily acoustic foam damped. The reason I'm asking is that I have the VR9SE Mk2 2016 model. I have found that the speakers were too close to each other (5'6" interior sides) than suggested on line so I moved them 7'6" apart, closer to the side walls. Also suggested was to tow them in 6 to 8 degrees. It appears to create a much more coherent soundstage. Also, since my speakers are 2 to 3 feet from the front wall, that the phase adjustment should be set closer to 90 degrees or greater, not zero, that zero is reserved for very close to front wall placement. I found that I get fuller, deeper bass with more open sound at 90 degrees. What experience did you have with center fill, especially on 50's and 60's recordings which tend to be left/right recordings with center reserved for vocalist or soloist?Not really. I was actually happy with my VR-9's until I heard the Ultra's. I just think the synergy between VAC, Masterbuilt and VSA is hard to beat.
To your point, I have always liked the sound of Evolution Acoustic MM3, NOLA Concert Grand Reference Gold 2 and Tannoy Westminster Royal.
Interesting choices...How do you find the VS sound compares with the EA, Nola and Tannoy?Not really. I was actually happy with my VR-9's until I heard the Ultra's. I just think the synergy between VAC, Masterbuilt and VSA is hard to beat.
Hi Leo,I notice that your listening room dimensions are similar to mine. I have a constrained layer damped 16" thick walls with built-in activated carbon bass filtering, 12" 3000 PSI steel reinforced floor and less damped ceiling with side walls and ceiling heavily acoustic foam damped. The reason I'm asking is that I have the VR9SE Mk2 2016 model. I have found that the speakers were too close to each other (5'6" interior sides) than suggested on line so I moved them 7'6" apart, closer to the side walls. Also suggested was to tow them in 6 to 8 degrees. It appears to create a much more coherent soundstage. Also, since my speakers are 2 to 3 feet from the front wall, that the phase adjustment should be set closer to 90 degrees or greater, not zero, that zero is reserved for very close to front wall placement. I found that I get fuller, deeper bass with more open sound at 90 degrees. What experience did you have with center fill, especially on 50's and 60's recordings which tend to be left/right recordings with center reserved for vocalist or soloist?
My VSA Ultra 9's and EA have similar sound to me; being very neutral but musical and non-fatiguing. The drivers in the Nola's were very similar to my VR-9SE and I could live with either. Tannoy (made in Scotland) always intrigued me but for the type of music I listen to (rock, soul, jazz) VSA was a much better fit.Interesting choices...How do you find the VS sound compares with the EA, Nola and Tannoy?
Thank you. Super helpful.My VSA Ultra 9's and EA have similar sound to me; being very neutral but musical and non-fatiguing. The drivers in the Nola's were very similar to my VR-9SE and I could live with either. Tannoy (made in Scotland) always intrigued me but for the type of music I listen to (rock, soul, jazz) VSA was a much better fit.
That confirms what Chatgpt instructed me to do and it certainly improved the soundstage and dispersion. While A.I. could not describe the size, weight, bass driver placement, dimensions on the VR9 or a photo of the active Ultra 7 (there aren't any on line) stating there are no bass controls (I corrected material facts), it is phenomenal at acquiring information on sonics, acoustics and electrical interactions. Eventually, I hope to upgrade to the Ultra 7 or 9 but I'm very happy with the former SOTA speaker I purchased 2 years ago. Damon set up my speaker as well as I am also sort of proximately located but I had a defective DAC when set up so the speakers ended up too close together and aimed straight ahead.Hi Leo,
I am fortunate to live within driving distance of VSA so Albert, Leif, and now Damon have always set up my speakers. My VR9SE mk2 were set up similar to yours and I was very satisfied with my soundstage and bass. With my Ultra 9's there is minimal toe-in now. I must point out that most of my music listening is from 70's to present so I am not sure that my experience will be of much help with earlier music.
I chose VSA due to it's phenomenal dispersion which I heard EA cannot compete with, being more directional. Guests have stood, sat, laid down and hear the same sound with only a different perspective compared to other speakers I've heard. I listen mostly to classical vocal and instrumental and jazz with some added rock from the 50's to the 80's. Also, a significant amount of both acoustical and electrical pre-tape recordings. VSA speakers do it all even if the tonality and tone density could be better on other speakers or omni speakers which can lack in other ways, the VSA balance and attributes are the entire package for me.My VSA Ultra 9's and EA have similar sound to me; being very neutral but musical and non-fatiguing. The drivers in the Nola's were very similar to my VR-9SE and I could live with either. Tannoy (made in Scotland) always intrigued me but for the type of music I listen to (rock, soul, jazz) VSA was a much better fit.
