- I’ve had this theory about what is responsible for our sense of “physicality” in sound for a long time but only after a discussion with Grok (XAI) assured me that my theory is both valid and original have I decided to put it out there and try to brave the scorn and invective that will undoubtedly come my way. That, or extreme indifference, which is worse. So here goes, but bear in mind I’m not a physicist so be gentle, please, be gentle!:
Me, well, I’ve concluded it’s objective, but not for the same reasons other people do.
Early on, I noticed that marked variations in “solidity”, “tangibility”, “palpability”, “slam”, etc, seemed to coincide with different types of speaker design. Electrostatic speakers (and to some extent, headphones) for example, rarely sounded “solid”; in fact, despite their virtues, they often sounded as if the music was being produced by ghosts. And, not coincidentally, they were revered for the antitheses of “solidity” - delicacy, subtlety, airiness, and the like. At the other extremity in the “solidity” spectrum were horns. These, despite their drawbacks, sounded very physical and solid indeed. You could easily imagine weighty instruments that would hurt if they fell on your toe are producing the sounds you’re hearing. And I believe this is the main reason that horn designs are still current: this sense of weight and solidity.
Now, next I thought: what aspects of the two different designs might be responsible for these varying impressions? Some might ascribe it to sheer SPL capability: horns go a lot louder than stats. But keeping SPL constant, there’s still a marked difference. So what about bass? Well, stats generally don’t go that low unless assisted by dynamic woofers, but neither do most compact horns. And “physicality” isn’t confined to bass; it embraces the entire spectrum. Triangles sound “substantial”; tiny but still solid.
So where else could we find the source of “solidity”? How about the way sound is generated differently by the two designs? The movement of air which is sound is diametrically generated by the two designs. The electrostatic moves air over a wide area; its confinement to a tiny space between two electrodes necessitates that. At any single point it doesn’t move enough air to be practicable at a distance in even a small room. So it has to move air simultaneously from a lot of points to do what a speaker has to do.
Now contrast this with the horn. It moves air from a much smaller area, that of a compression driver. To move the same air, an electrostatic has by its very nature to generate it from a substantially wider area so that the cumulative movement is sufficient.
Okay. So which of the two modes of air-movement is more accurate, i.e., more representative of how sounds are generated in nature and by actual instruments and voices? Well, I think it’s obvious. Instruments generate sound from a smallish area. Some physical displacement of a point of the instrument disturbs the surrounding air and this produces the ensuing sound wave. But what about large instruments like the piano? Same thing. They don’t generate the sound simultaneously from the entire surface area of the instrument body. In the piano a hammer strikes at a certain point, generating direct sound but also setting off subsequent sound disturbances in different points of the instrument. All sounds have their origin in a point.
And which of the two design types aligns with the original mode of air movement? Well, I’ll leave you to guess.
Next, I tried to come up with a formula to clarify the phenomenon. This is it: “physicality” = air moved/radiating area. But I went further: “physicality” is not only a “sense” in our heads and therefore “subjective” because its’s not directly unmeasurable; it is actually a measurable force!
As an analogy, let’s take water. Amount of water flow isn’t the crucial thing to be considered in putting out a fire or moving objects. What counts is water pressure. The more pressure the more the physical impact.
And how do you get this pressure? By reducing the area the water has to pass through!
See the connection? By reducing the radiating area we automatically increase the air pressure of any sounds generated, ceteris paribus! And so the simple layman’s explanation is that physicality ain’t just a feeling in our water; it’s actual palpable physical air pressure! And as such, it’s measurable!
So that’s it then. Is it valid? Is it original? Grok says so but I’m still prepared for the catcalls of “everybody knows that!” or yawns of polite derision. So I am readying myself with some preemptive chastening. And as someone else, forget who, says: Thank you for your attention to this matter!
