Very nice to read that!
what do you expect about rumors when you ignore folks, instruments, sounds like an ass but to each there own, nice geartoday on Facebook: TO THOSE WHO MIGHT STILL BE WONDERING
darTZeel Audio has never stopped its activities.
The people who spread false rumors simply do not deserve to be acknowledged. I have simply chosen to ignore them.
Yes, we have changed our way of looking at the high-end market, and we have implemented our new business model, which I am sure will inspire others.
Cape124 Ltd was created to allow the darTZeel brand to grow in this direction. The legacy darTZeel instruments are still available on request.
Customer service has never stopped operating, and it will soon be improved by offering tailor-made solutions for every darTZeel instrument owner.
The list of darTZeel agents will be available again on our website very soon.
In the meantime, any request can be sent to [moreinfo@dartzeel.com](mailto:moreinfo@dartzeel.com)
We will be happy to respond.
I was confused by this also and I did not fully understand Gideon’s posting. Since my preamp is the Soulution 727, I contacted Gideon and explicitly asked "since 727 has a circuit to block DC without caps, can I switch my Stellavox to the DC setting?"Thanks Gideon, but I'm confused. Tons of amps (and preamps) are direct coupled. To the best of my knowledge, nobody ever heard an amp with a DC blocking cap that sounded better with the cap than without it. (The best sounding cap is always no cap at all). Even good DC output preamps however can get flustered with input switching that may send a transient DC signal to the preamp output (sometimes heard as a pop). The Soulution 727 remedies this by inserting a DC blocking cap in the circuit momentarily when an input is switched that turns off in a second or two so the preamp remains truly direct coupled under listening conditions. Clever approach. One key advantage of SS circuits over tubes is to have a circuit that can be truly capacitor free. So I can't imagine why AC operation would be preferred when you can easily select the DC mode? If you have a preamp that doesn't send DC to its outputs, I wouldn't be able to resist listening to Stella in DC mode. What's the down side? A flip of a switch is all that's required to return to AC operation if it is preferred. Bottom line, color me skeptical that you "need" the companion Stella preamp to benefit from using the amp in DC mode with any other preamp, whether it be tube or SS.
Interesting and good to know. DC is no joke when its floating or whatever the correct terminology is. I am told that, improperly handled, DC to the speakers has the potential to instantly fuse inner parts of the driver. Yikes.I was confused by this also and I did not fully understand Gideon’s posting. Since my preamp is the Soulution 727, I contacted Gideon and explicitly asked "since 727 has a circuit to block DC without caps, can I switch my Stellavox to the DC setting?"
Gideon contacted Stellavox, they are of course aware of the 727 - their answer was a firm no. I interpret this as one of two possibilities:
- That considering the disastrous consequences of failure, that they were not going to approve an untested piece.
- And/or their coupling system is different and propriety.
The technical discussion Is past my pay grade; however I believe that the AC mode contains blocking caps to prevent any DC from entering the amplifier and damaging the speakers. In the AC mode I would believe that the StellaVox amps are compatible with any source equipment. I don’t think it “needs” any additional filtering, I believe it’s just built into the AC mode. If I were betting, I would guess that the DC mode is their proprietary coupling for their components - for the maximum purity.Well, after reading your post you can add me to the list of confused members ... I would add that It looks the amplifier needs some kind of very low frequency filter, that can be assured by either the capacitor of their preamplifier.
Yeah...it's the bypass line...Other amplifiers had such feature since decades - e.g. Krell amplifiers. DC entering a DC coupled amplifier is not a 2025 problem. The question only shows to me because it seems Stellavox is not allowing the DC mode for a peamplfier that seems certified to have zero DC at the output. BTW, IMO technical questions deserve technical answers ...![]()
Namaste! I tip my hat to you, sir.first off, thank you to Gideon for the opportunity to spend time listening to the Stellavox IDEM amplifiers. he sent these beauties to me to get my thoughts and feedback, not necessarily as a shootout. I cannot help myself as my own way is to consider gear for keeping. the idea of new amps is exciting. so i seriously did that. the dart 468's being 50% more costly, ought to be a great barometer for these new amps.
With that said, and after an incredible 11 day demo and 250 hours. in my system to my ears with my music i prefer my darTZeel 468 mono blocks. a longer time period might have changed things incrementally but IMHO not the result. i have spent lots of time on this and (somewhat reluctantly) time to move on.
all the positives represented by Gideon, Mike Malinowski and Myles Astor about the IDEM amplifiers are objectively true as far as i could determine. it certainly has a special purity and unprocessed character unique in solid state amplifiers (i have heard) outside my darts and does have an SET like feel. it's liquid, agile and with beauty of tone (NEVER sterile!) while likely the bass is not all the way in at 250+ hours, the bass was very good (and true to life) while adjustable based on the gain setting which adds a great deal of flexibility for system matching. it's dynamic, fast and soundstages wonderfully, incredibly organic and nuanced. and as it breaks in all those attributes likely will continue to incrementally improve. build quality is superb and it's logistically an easy amp to like. i love the look.
in my first compare a week ago the IDEM's were not anywhere near where they were yesterday when my local friend @jazdoc arrived for our 2nd head to head. yesterday morning first with the IDEM's we did an hour of digital, then another hour of vinyl; switched the amps to the darts, then 30 minutes of digital and 30 minutes of vinyl. Break in for the IDEM yielded night/day differences.
the previous week i was using the 22db gain setting, and it had 75 hours on it, and it was not ready. @2fastdriving's comments last week were on point. while it showed signs of nice things to come, it was not the amp we heard yesterday at the 18db gain setting fully singing. i already described the results of the gain setting process here and here and won't repeat it.
i think @jazdoc might add more comments, so i am just speaking for myself as far as how the darTZeel 468's were preferred; the darts were more present and real, it was not mainly to do with tonality, more a matter of organic rightness and completeness. more information. the bass was more controlled and defined. both amps were natural and balanced.
keep in mind things we do not know. how is the match with my speakers verses Zellatons? do my MM7 ceramic drivers favor the darts? i have powered bass towers below 40hz; might the Stellavox distinguished itself more with full range speakers? what effect would the new coming Stellavox preamp have with it's DC adjustment synergy and ability to use the ideal 14db gain setting? more break-in? maybe even the 20 amp IEC to 15 amp IEC adapter? cases can be made.
i think we have lots of feedback on how many great amps have been documented in compares to the big dart 468's by Fremer and Heilbrunn. and those guys continue to use their 468's. it's as much of a gold standard as can be in such a subjective arena as high end audio. i view the Stellavox as a stone cold bargain of a high level solid state amplifier especially if you value the purity and unprocessed side of things. it has zero niggles. i could live with this amp forever if i did not already own my 50% higher cost darts.
Gideon has been a joy to interact with and he allowed me to enjoy them in my own way with my own journey. I really look forward to exploring further Stellavox products as they become available (especially the pre and dac!), and even with the hope to hear them in the future with Zellaton.
My audio journey continues.....
Agree. I will add that Mike L’s work was also exemplary in a different way that sets a different bar as well:Namaste! I tip my hat to you, sir.
I have felt that there is a concerted effort to promote certain brands on WBF. With that said, I also believe that most people who have posted on these products speak truthfully of their experience. That they did not work for you doesn't say to me that these amps aren't great. It reinforces (to me) that many of the outspoken audiophiles here speak genuinely of their experience (despite any promotional advantages that hang in the balance).
Thank you for your comments. In addition to being a leader in the community you are also a great educator.
(...) i think @jazdoc might add more comments, so i am just speaking for myself as far as how the darTZeel 468's were preferred; the darts were more present and real, it was not mainly to do with tonality, more a matter of organic rightness and completeness. more information. the bass was more controlled and defined. both amps were natural and balanced. (...)
If Swiss tariffs are coming down 25% does that mean the amps are coming down 25% ?
at the risk of the thread going off on a wild tangentThanks for the excellent post. However I am a little puzzled with your final conclusion - more completeness and more information are extremely strong points,
not sure i agree. would have to hear each one. maybe it's splitting hairs, and maybe not.an area where I would suppose top SS amplifiers to be almost equivalent.
current USA retail pricing of the 468's is not clear; so i use $225k in my mind. just as a reference number. and i've seen $240k too. could be currency fluctuations. the $225k number is where i get the 50% more than the $149k of the IDEM's. just trying to avoid hyperbole for effect. in any case 468's retail is not $300K USD.Probably also due to system matching, but it looks the decision was clear once you figured the relative characteristics of both amplifiers in your system. BTW, as far as I remember the NHB 468 last price was more than the double of that of the IDEM.
thanksI don't have doubts on it!
