ok, i was able to find the quick connect banana plugs, and stick my ground cable spades into the barrel and tighten it and so hook up my Tripoint Troy Sig to the IDEM's. not ideal metal to metal connection, but even so a bit of added air and lowered noise....and mid range textures. just a little. and after a few hours connected the Tripoint does engage a bit more.
later i listened to those vinyl cuts from yesterday, and based on my reference memory we are firmly in the general darTZeel reference territory for body and tone. it's familiar to me now and does not stand out as missing anything. flow, energy, scale and bloom are good. all of which is progress, but not a head to head either. i did play some serious vigorous bass performance cuts and i'd say very good.....but need to do more. and i suspect we are a week from the bass coming most of the way in.
is there more nuance and sparkle here and there in my reference cuts? more musical truth? more action? there could be. or just a little different? does it justify a change....yet? the darts are hard nuts to crack. at least we have a presentation now that is apparently complete and working well. no way you could characterize what i'm hearing NOW as lean solid state. (should i be less definitive without a head to head?
) moving to the 18db gain setting and the additional hours has brought us far. they arrived brand new, unsettled, and cold as ice less than a week ago (last Wednesday noon).
on we go.
on we go.
