Maxim,
Of course - criticism (or its euphemism, "advice") is always welcome!
Fundamentally, what you modeled is no different from calculations done in mid-2023 (see links below), regarding room nodes. Recent REW measurements were done without any doors installed, leaving a gaping hole to the outside room, which could have contributed to the erratic room node response. The JBL subwoofer's vented bass port is likely tuned to around 50-55Hz, which could have be the source of the outsized source and resonance peak.
My room dimensions are closer to those below (9.71mL x 7.10mW x 4.2mH), so the inputs into your program needs to be tweaked.
Regarding asymmetric surfaces, due to the sloping carport between the road and house, the ceiling is actually at its highest at the R corner, but slopes down 400mm towards the far L corner, creating one large non-parallel surface relative to the flat floor. Also, the dampened plasterboard system is definitely not a simple single-layer 9.5mm one. Under the VPR's steel plate surface, there are five more layers underneath before reaching the base layer of reinforced concrete. The swimming pool projection also reduces the ceiling height at the back wall's ceiling, introducing room nodes at slightly higher frequencies compared to the rest of the listening room. See the two links below:
The Linkwitz LX521.4 system was outstanding - no - astonishing! The digital source was in plain-old CD resolution, streamed via an integrated streamer/DAC with no fancy ancillary cables or other equipment. I can expect that with a statement streamer like the Aurender N30 or Taiko Extreme with...
www.whatsbestforum.com
I've never claimed to be building "perfect" listening room, just that I'm trying to optimize what's possible with a large room in the basement whose bass room nodes will be extremely challenging to tame, give how bass pressure will mostly be "trapped" with nowhere to go. Many may be surprised hear me say this, but even a smallish 3dB reduction (halving) of room node energy by the VPRs would be a welcome result, and anything more would be a bonus. Most audiophiles vastly underestimate the magnitude of the bass pressure waves, and the heroic amounts of mass (and space) needed to reduce the amplitude by even a small amount.
You've likely missed my post back in Nov 2023 (see link below), but the VPRs were calculated and tuned (via metal plate thickness, mass, and size) to address the predicted bass problems. In all likelihood, there will be no need to tear out the VPR panels, as they will not be harmful in any way acoustically.
...cool stuff @QuadDiffuser Did you find a good source for the pellets? I dove into this a few years back and ran into a dead-end for a source. And shipping was brutal.
Once the 5,000kgs of QRDs are installed as the final 7th layer, a number of positive outcomes are expected:
1) absorption of the 150 - 500Hz frequencies will diminish, via suppression of the exposed perimeters of the VPR metal bass traps
2) diffusion of the 185 - 3.4kHz frequencies will rise, via the P23 QRDs on the front wall
3) diffusion of the 225 - 3.4kHz frequencies will rise, via the P17 QRDs on the two side walls
4) diffusion of the 300 - 3.4kHz frequencies will rise, via the P13 Skyline 2D diffusers on the ceiling
Overall, these measures will rebalance the room’s spectral and time‑decay characteristics while creating the highly desirable psychoacoustic effect of making the boundary walls seem farther away - an illusion that effectively doubles the perceived room volume.
As I typically listen to music averaging below 80dB (but should still be highly articulate and expressive, thanks to the sub 20dB ambient noise of the room), I will leverage certain psychoacoustical phenomena such as insensitivity of low frequencies (ie. room node peaks), and masking/precedence effects to reduce the audibility of bass anomalies. I also expect PS Audio's AVAA active bass cancellation units and Von Schwikert Audio's room node cancellation subwoofers to help flatten room node peaks (and lift the cancellation nodes) to achieve a more linear amplitude and decay in the lower bass region, to more closely match the characteristics of the upper bass / lower midrange.
