i enjoyed my time with the big VAC Statement 450's in my system. a lot to like. it could handle complicated music for sure. in the end i preferred the darTZeel 468's solid state, but likely other solid state choices at that time might have bowed to the VAC. generally i lean toward tube amplification too, but not heard the best non-darTZeel current solid state offerings......yet.
Of course it also very much depends not just on the type of tube gear, but on how easy the speakers are to drive. Mine are a very easy load by impedance (high throughout) and phase angle characteristics.
For many if not most non-horns the best choice may be solid state, at least when it comes to the power amp.
in early 2017 i had a fork in my digital road. i had a modestly priced solid state Aqua Formula dac demo unit i compared to my Lampi GG 1.5. head to head it was clear (pun intended) that the more demanding the music, the more i was hearing the music with the Formula dac, and hearing through something to get to the music with the GG 1.5. sure i liked the tube sound, it was beautiful, but on much of the music it was in the way. i had plenty of tubes to roll. this was a big surprise to me. but undeniable.
6 months later i ended up buying a used MSB Select II to go further down the solid state dac road.
this was in my system, to my ears, head to head on the music that was most important to me to be the most satisfying. big complicated music in a big room without limits was my priority. still is. with the Wadax i think i get it all with any type of music; truth and beauty. digital has come a ways.
other ears and systems and music focus might have taken the other fork. the Lampi GG 1.5 was a sweet dac. could live with it forever and not look back.
The Lampi GG was much better than the Select 2, in my comparisons, and since then there have been other similar reports of maybe Pacific or so. For complex classical.
For me personally I do not prioritize clarity and information retrieval. I am looking forward to hearing Horizon 360 in direct comparison to Varese to see which is my personal preference.
I am a single issue voter. If the LampizatOr has greater "breath of life" on vocals, then for me personally it is game over.
Amir, you seem to be describing an either/or condition and a choice. What if the listener’s goal is to have the best qualities of both of these scenarios? What source would you then suggest?
Dear Peter, I think it is not possible (maybe my experience is not enough) if you listen to all music types. After 2005 I convinced I should have two audio systems.
first system : tube system (like kondo living voice vox microseiki or Lamm Vitavox AS …)
Second system : Solidstate (like ASR Emitter Vitus Kharma Gobel TAD Wadax Weiss …)
I believe tube system is more emotional/natural and solidstate is good for some type of energetic music (like supertramp).
High performance analog/Tube/horns are finally winner but I like good digital/solidstate/cone systems too.
I believe the main problems of the sound is more related to speaker position, ac power quality, noise rf vibration and SNR problems and system matching/setup.
I know that like non audiophiles think all audiophiles are the same, and digital people think all analog guys and records and tables are the same, your knowledge of SETs and horns makes you think Brad and I are similar.
Then how is what Brad thinks relevant to when i make a comment on low powered amps. If Mike says something on SS, does anyone tell him oh you are completely disagreeing with what Marty says. Did anyone tell Pk LA in his recent thread what Al M thinks about Schiit dacs? People group others together when they don’t understand the nuances or differences between the different players
That is a silly question, to generalise so simply. But I haven’t heard SETs above 50 I would want, except for one, and that too it is not close to what very low watt SETs can do with appropriate speakers. But push pulls yes. AR, Cat, VTL, Ayon, CJ etc
Also my poor comment was on high powered push pull amps, which I listed, not on sets. Sets are better than push pulls, just not as good as lower watt sets, so yes I still wouldn’t want them
As with every category, there is bad, good better and best. What becomes interesting is how do the various best compare for the individual?
I don’t think Brad or Bonzo or anyone in the vinyl SET Horn camp thanks everything there is good. Likely most are rejected as bad. Nuances and preferences depend on individual experience and exposure and preference and likely most on what the speakers in the room are.
I find also interesting that Ralph is the one who discusses his tube designs more than anyone else. Consensus is fairly hard to find.
it should be hard. so many variables. but sometimes it happens.
to me the sensitive part is when some amp topology/output category gets dismissed/diminished/generalized. it's really never quite that simple to reduce it like that. horses for courses and all that. i realize it makes it easier to throw labels around and make strong concise points. and rally the troops.
