So is the Incito (Prestige Series, embedded PS, €10800): 33 Kg / 73 lbs.The Incito S is mostly transformers. It is very heavy for its size.
(but its wooden crate is much smaller
It is exactly that synthesis that I no longer expected, that I instantly got from the Incito (Prestige Series, embedded PS) when I heard it at home.l like density and weight too. Its hard to find it with articulate, natural, true to voices and instruments.
Hopefully the A C gets you both.
Compared to my YBA 1 preamplifier (with separate PS), the Incito even delivered slightly better transparency. But first of all, it delivered more density and more true-to-life timbres and colors, evenly spread on the whole range, a bit like a scientifically restored Quattrocento fresco, along with an even more exquisitely refined treble (though YBA gears are very good at that too), more dynamics and deeper, wider and as accurate sound-stage image.
(Attending countless live, un-amplified acoustic concerts - 46 last season alone -, in various venues, made me sensitive to tone, dynamics, transparency and rhythm. By contrast, I admit I have become less obsessive with image accuracy, TBH.)
Technically, given their specific circuit topology, both Incito and Incito S can face a 250 Ohms load downwards (two hundred fifty Ohms).
Regarding the cause of the "edginess" previously endured:
Apologies but I haven't read this very long thread comprehensively. Nevertheless, I have a vague memory: aren't your Italian monoblocks rather low gain (or at least, not-so-high-gain) ?While higher gain in the preamp doesn't electrically change the output of the amplifier (it only increases the input voltage to the amplifier) I suspect there must be some way in which the Italians are now better impedance matched to the preamp or experiencing less stress.
If so, isn't the present relieve regarding that past edginess simply due to the fact that, IIUC, your system now "complies" better to what Aries Cerat promotes: a better overall balance of the gain throughout the whole system, that is, in practice, to "move" more gain upwards (so, high-gain sources and preamplifiers, preferably), and lower the gain of downwards power amplifiers; in order to endow the system with a sepulchral silence.
In this hypothesis, deviation from that "overall gain balance" advised by AC (deviation= your previous setup, with too-low-gain preamps) would have generate enough distortion (not easily identified as such though), subjectively perceived as "edginess" ?
(I am aware that, technically, this argumentation is rather vague and shallow)
