There is no Basis distributor in Europe these days.
The Basis Synchro Wave, Naim Armageddon, Dr. Fuss Netzteil, VPI SDS and other devices recreate a better sine wave for the AC motor, as far as I know.
I already use such a device; Stromtank for all front end components.
Would an additional device as listed above bring further improvements?
Motor unit: both caps and the resistor measure ok.
Now … which power cord for this tt?
Thx for your advice!
I don’t think so. Damn. You had said that before. My fault.It will not do any harm - I have bough a vintage PSAudio P300 to drive my turntables with synchronous motors in the past. The good thing was that I could adjust voltage for minimal motor vibration.
Probably they will measure nice when not operating. Did your engineer measure the voltage across the coils at startup and when stopping?
Not so important if you wanted a real upgrade then a two-phase powersupply is recommended it removes the motor vibration and delivers a clean voltage to both coils.Now … which power cord for this tt?
I think you are right.
But. Which 2 phase power supply to match this unknown motor?
(...) Disappointingly, after trying a decent selection of otherwise good sounding "audiophile" caps, the winner was the original Siemens, perhaps polycarbonate capacitor. All the caps sounded unmistakably different from each other.
Maybe send the motor box to Dr. Fuss to make a taylor made unit, correct phase angles and all.
For the Windows PC ?Well, next step is a decent power cord.
Direct connection to the motor coils , no cap and resistor needed because the phaseshift is done in the powersupply.Most interesting!
With a 2 phase power supply …
Do I keep caps and resistor in the motor unit?
Do I remove them and connect the 2 phase ps directly to the motor?
This is a better motor 3mm shaft so the pulley will fit speed can be set at the power supply .My engineer friend seems to have succeeded.
He used super glue to fix the magnet at the shaft again.
Analog music is back again in my home.
Nevertheless, I am still thinking of a better motor and power supply.
Or simply a two phase motor controller.
This is a better motor 3mm shaft so the pulley will fit speed can be set at the power supply .View attachment 158480View attachment 158481
Dr. Bernhard Fuss suggested a lower voltage AC motor as well.
He seems to favor Pro-ject motors.
I would need a new pulley as well for that or use this one:
Motor für Pro-Ject RPM 1.3 Genie
Original Pro-Ject Ersatzteil. Motor komplett für Pro-Ject RPM1.3. Teilenummer: 1949576015. Lieferumfang: Motor incl Pulley, ohne Netzteil, ohne…www.vinylnerds.de
IMO the pulley is the more critical component in the system - any small microscopic deviation from concentrically will result in wow and flutter. The fit of the pulley to the shaft must be thigh. I had a few spare motors, but was not able to use them as I could not to get the optimal pulleys.
Thorens used these motors very reliable mechanical build quality very good close tolerance sinterbushings.If getting a motor from Berger I would suggest a low voltage type, such as 8 or 12 Vac - it will be much easier to build a two phase a controller.
BTW, can we know why do you consider that the Berger is better than the original motor?
