For me, it feels a little strange how tube amplifiers – especially in combination with horn loudspeakers – are often discussed. Once you’re dealing with sensitivities of 100 dB, and even more so at 110 dB, the main issue isn’t really about tonal character anymore, but first and foremost about the ability to be completely free of noise and hum.
A truly “black” background is the basic prerequisite for being able to enjoy microdynamics at all.
I personally ended my phase of experimenting with tube preamps, tube phono stages, and tube power amps almost ten years ago. At some point, I simply felt my time was too valuable. By then, I had gone through around 30 preamps, 15 phono stages, and at least 50 different tube power amps in my system – often running two or more in parallel for direct shootouts. In the end, only three of them were really satisfactory in terms of being hum- and noise-free, one of which was a DIY amp with just 0.5 watts of output.
As for power: in my own system, peaks rarely exceed 0.3 watts. That’s why I find some of the statements about “necessary power reserves” a bit overstated. Of course, it’s always nice to have more than you strictly need – but with horns, I think it’s much more important to focus on absolute silence in the background than on excess power.
Of course, tubes and horns are closely connected – if only for historical reasons. And naturally, there are some wonderful combinations out there. But let’s be honest: a horn doesn’t need tube electronics to fully unfold its immense strengths.
If anything, it’s the other way around – tube amplifiers often need horns, and sometimes even full-range drivers, in order to really show their advantages.
That’s not to say I consider tubes the “wrong” choice per se. Not at all – they’re beautiful to look at, they keep you warm in winter, and in just the right combination, they can make truly wonderful music.
Best Regards S
