PSVANE - Let’s Talk All Things about Vacuum Tubes
I must say, choosing the EL34PH is a truly tasteful decision. It is one of the finest products we have ever made, offering an almost perfect reproduction of the legendary Philips EL34 metal base in terms of sound. Its quality is quite solid—provided there are no issues during transportation.
As for the ACME KT88, its sound characteristics are relatively neutral, with clear layering, excellent dynamics, and a strong yet flexible presentation.
Thanks for your response:
I have purchased 4 new tubes from your brand on your website, HORIZON 6SL7 and 6SN7; I hope they match very well with the EL34 PH
Reactions: PSVANE
A week ago I received the order for the Psvane Horizon 6SL7 and 6SN7 for my Cayin CS-88A, purchased from the official PSVANE store; They have arrived perfectly protected so as not to suffer any damage, the shipment has been made at all times with a tracking number. At this moment they are still burning but I can say that the sound is excellent, I also have the Psvane EL34 PH installed as power tubes; and the first impression I have with the combination of all of them is that the bass is reinforced, they are more spacious, there is more detail in the sound and the voices are very velvety.... I am very satisfied with all of them, I previously had the Gold Lion KT88 installed and they sounded like transistor equipment to me, I have not yet tried these tubes again with the new ones from the Horizon 6SL7, 6SN7 series, but I will; They will surely transmit more power and space.... With the EL34 PH the first impressions are excellent, good space, warmth, softness but plenty of power, tight bass although a little more extended than with the Gold Lion, very marked mids with impressive voices and extended highs (with the combination of the Horizon series I have the impression that the highs have increased a little with respect to what was seen with the EL34 PH and the stock tubes)... My entire amplifier is now with tubes. PSVANE and when I hear it I can't stop smiling, the only unknown will be the durability,... we'll see what happens.....
Reactions: PSVANE
‼️PRICING ADJUSTMENT IN THE US MARKET
Dear Valued Customer,
Due to the recent increase in tariffs by the U.S. government to 104%, we regret to inform you that we must adjust the prices for the U.S. market. Starting May 1, 2025, prices will rise by 18% to 25%. Although this adjustment will not fully cover the additional costs, it represents our best effort.
To express our apologies, we assure you that we will maintain the current prices until May 1, 2025. We remain committed to providing high-quality products and services.
⚠️Price Adjustment Scope:
PSVANE Official Store: https://psvane.co/
PSVANE Amazon Official Store:https://www.amazon.com/-/zh/stores/PSVANE/page/6752D1BF-8FA3-4DB3-8672-05848278CB66?ref_=ast_bln
PSVANE AliExpress Official Store:https://psvane.aliexpress.com/store/1104301571?spm=a2g0o.productlist.main.8.16c8WqgxWqgxa6
Tell us more about the new Summit series.
The PSVANE SUMMIT series is our top-tier line—built for serious audiophiles who want the very best. It features our most advanced coating tech (HPC), which improves electron flow, keeps things cooler, and helps the tubes last longer with better sound clarity—especially in the highs and lows.
Unlike regular tubes, only about 2–3% of each batch make the cut to be called “SUMMIT.” They’re hand-picked for the best performance and go through a 30-hour extra burn-in to make sure they stay consistent.
If you're asking about the 845 in particular—it uses a patented multi-layer anode design that solves heat and current flow issues found in high-power tubes. So even at high voltage, you get stable, clean, and linear amplification.
In short: better build, tighter QC, more transparency, and more power with control. It's the best we offer right now.
Reactions: Croc999
Thanks for the info!
So they're above ACME?
My amps actually use 211 (currently Psvane's Audionote version) + 300b + 6sl7.
Can a time-honored vacuum tube breathe new life into modern sound reproduction? Can it still reach the pinnacle of technological refinement? These are the questions that have driven our continual exploration. With the launch of the SUMMIT series, we are confident in declaring—we have reached the summit.
Through our latest breakthroughs in vacuum tube manufacturing technology, we have pushed the boundaries of audio performance and engineering integration to an entirely new level. Join us and explore the summit of perfection.
Hola, gracias por tu pregunta.
Para los tubos de vacío de audio, la jerarquía de nuestra línea de productos es la siguiente:
Básico: HIFI, Reino Unido
Seleccionado: HORIZON, ARTE
Premium: NOSOTROS, ACME
La Serie HORIZON es nuestra última línea, con un sonido más neutral en comparación con la Serie Art e incorporando las últimas tecnologías, como el recubrimiento HPC.
La serie WE rinde homenaje al sonido clásico de Western Electric.
La serie ACME es nuestro verdadero buque insignia y ofrece un perfil de sonido neutral y completo.
Muchos usuarios han compartido sus experiencias con la serie Horizon. Puedes buscar reseñas más objetivas en YouTube.
¡Hola!
Para la opción de tubo PSVANE EL34, ¿cuál proporcionaría ese sonido más clásico, suave y aterciopelado de los tubos vintage?
¡Hola!
¡Hola!
La WE EL34PH es una recreación clásica de la legendaria Philips EL34, que ofrece un sonido suave, sedoso y relajado, fácil y agradable de escuchar.
I am glad for this news.
I ask:
-do you finally indicate transconductance ( Gm ) or are we still at the miserable anode current?
-The earlier Acme's, as in the old American globes, did not have superior mica supports. The new Summit ones do. Why? It simplifies assembly but the mechanical insulation of the structure is inferior.
-How many years of warranty?
-What service life do you estimate?
Thanks
@PSVANE
Could more details be obtained about these tubes? I notice a singular opacity.
Is this blessed hpc coating on the emitter layer? If so, how can it work on both barium oxide and thorium tungsten tubes, which have a dramatically different operating principle and operating temperatures.
Can some more data be obtained?
I remember that they cost slightly less than WEs where there is a far different guarantee and much greater transparency on data. How do you buy blindly?
Thanks
@PSVANE
Thanks
Hi - honest question - Isn't it the same if you buy Elrog, Taki, Stradi, Cryotone and other 300B's?
I thought most people bought on how they sound, not what a company claims about the technology?
I have listened to them and compared them to the WE and others which tells me far more than what a company puts in its marketing pamphlet. I don't rely on companies to tell me how something will sound.
No. Excuse me.
Let's remember that, it's the manufacturer who claims to sell you two coupled tubes. Okay. Coupled for what? I want to know.
Just stating the anode current does not show great intelligence.
I need to know if I can use this pair of tubes in a pushpull.
In this case, the anode current, is also a useful but insufficient indicator. If the Gm's are very different from each other, the even-order distortions will only partially elide.
Even in a single ended if the two end tubes do not have similar dynamic parameters, you risk finding an imbalance between the two channels.
WE, which I own, attaches the parameters of the tubes you buy and other data ( and I was able to remeasure them and they are true ).
EML, which I have, states the Gm and I have been able to measure it.
Elrog, which I own has a low Gm for genetic reasons but Mayer is forthcoming.
Why won't the Chinese producers declare the parameters?
Sound ( especially in pushpull ) is made not only by the goodness of the devices and subjective aspects but also by the similarity between them.
If I pay for two matched tubes, the manufacturer has to show me how he did it.
Comparing end tubes with the same driver tubes could be misleading. Harmonic cancellation always lurking, could also make you make huge errors of judgment.
In summary, the data provided is not an indicator of tube quality. They are an indicator of the seriousness of the manufacturer.
Reactions: oldmustang
Sure. What ever you say.
I learned a long time ago what someone states any measurement on a tube it is guaranteed to be different on your own tube tester. And honest tube sellers state that.
In most instances two exact tube testers will show two different results on the same tubes (unless you have some weird home made tube tester),
But what ever makes you feel better you should do.
We are not measuring very high Gm tubes and, more importantly, I have never claimed to match tubes with ridiculous instruments like TV7 or Funke W19.
Feedback on the claimed measurements was also had by Boele ( see his wonderful article testing the new WEs on AudioXpress ). We are not talking about esoteric arts. With calm and patience even a DHT ( which of its own presents difficulties ) can be measured well.
But, in the end, what is the alternative?
We were talking about the proper burden of providing data on the part of the manufacturer. What can a normal enthusiast do if he cannot rely on truly selected pairs of tubes? If you have a pushpull with no feedback what would you do?
I can select them but if the selection offered is poor, I end up having to buy more tubes. I can control the reciprocal acting of dynamic parameters on distortion by going to check the spectrum of distortion.
In a single ended, I can check the real balance between the channels ( which also depends on the tubes used if there is no feedback ). And manage the tubes to get the correct harmonic cancellation ( which must be right. Not too much, not too little ). What can a normal enthusiast do if they don't offer you seriously selected tubes?
I demand this from a seller. You go ahead and do what you want.
Sorry
P.S. example data of tube Stradi
Sorry
You are free to demand what you want.
I'm going to go listen to beautiful music from tube amps rather than get all stressed over nothing.
Happy listening!
Happy listening!
To recapitulate.
Many tube manufacturers provide decent, verifiable measurements. I, as a DIYer, appreciate this attention to the user.
If you are not interested in them, or if you do not understand them, that is your problem alone.
Are they stupid in WE, in EML, in Stradi to provide them accurately?
The question is simple. I don't think they are all onanists
Regards
