Really , Why ? Perhaps you might expand upon your comment a little further .Also, no tubes! Two strikes. I’m guessing the system was chosen more for its looks.
The Klipschorn is not just any speaker. It’s rated 105 dB in efficiency. Even one watt into a KHorn will blow your eardrums. It’s tailored for a SET amp. With my La Scalas, about the same efficiency, I’ve tried a variety of solid state amplifiers, from very pricey ones to Pass’ First Watt. Compared to any of my three SETs, they uniformly suck IMHO. But it’s just my opinion. If you like the sound of solid state amplifiers on a horn, knock yourself out. I don’t.
Nice,Until (fairly) recently, I had 2 stereo systems: one with Magneplanar 3.7i's for when I wanted to immerse myself in detail; and one with LaScalas when I wanted, as they say, "to ROCK"! I can't think of two speakers more diametrically opposed than maggies and Klipsch, but I truly did love them both. And, depending on my mood or my motivation, either was the best in the world, for me.
As I have - uh - aged, I've decided to not subject myself to the 120dB peaks any more and I settled on one system with 30.7s. They are the loudest "good" speakers - or are they the best "fairly loud" speakers? I never heard the IRS, but I imagine it was both good and loud.
If I was young again and less concerned about ear bleed, I would own Klipsch Jubilees - I owned them briefly in my transitioning stage.
Hi mate,Sorry I have been off of here for a while.
Rob, The Jubilees are almost magical. Great dynamics and fairly deep (and very hard-hitting) bass, without the "boom and shriek" of the original KHorns (or Altec's VOTT, which I have also owned). 80 years of production OUGHT to yield some improvements - and they have/are.
I am often "amused" by how staunchly people defend what they happen to own, now. I have owned so many speakers in my life I'd have to sit down and write a list. And ALL of them have their merits. There were speakers that SHOULDN'T sound good by design, but did ((DQ10's, as an example. Seriously? a $5 piezo tweeter!) and there were speakers that were so cheap that they shouldn't sound good, but did (Radio Shack's Mach One). But EVERYTHING I have experienced fall into one of the two camps: "good" or "loud" - I have never experienced both from a pair of speakers. I think, but do not know, that the IRS probably did both. I had some Reference Standard 2.5's and some 4.5's and both sounded really good to me at the time.
Give the Jubilees an audition. They might fit YOUR bill.
www.instagram.com
BTW, i believe it absolutely possible to achieve good and loud!Sorry I have been off of here for a while.
