Either they don’t have the technology to implement proper vacuum hold-down, or they’re simply choosing to skim people with fancy marketing and a basic clamp. At least they should accept this fact and add a washer and screw down clamp as the second best thing.
I haven’t come across such claims, but IMO if you’re going to generalize that “many reviewers” say it, you’ll need to show more than two examples. Even then, their method is flawed. Simply disengaging the vacuum hold-down is not a valid test. A proper comparison would require removing all the vacuum hold-down elements (rubber lips, etc.) from the platter and then listening with a different mat. None of them do that.
And what exactly is wrong with control and silence? If someone prefers the artificial vibrations caused by a floating or loosely coupled record, that’s their choice—but those artifacts are not what’s cut into the grooves.
