Swiss Digital Fuse Box Anyone?
Reactions: corepowertech
User programmability aside, how is it different from the SDFB?
Very similar circuitry - but as noted, No Micro Processor (and support hardware/software). This uses a dip switch for all selections. I'm super pleased with it and early adopters are very enthusiastic. Lower Cost is nice - as Fuse Box will have to go up at least $50 to $75 dollars shortly for both Tariffs from Japan. (UGH)... Over $100 for SDFB MAX... The Hall Effect Sensor is Mil Grade and perfect for the task.
I always try to be as transparent as possible with you ladies and gentlemen - even when some comments push me off kilter :)
I have some nice pictures - maybe I should post these later
Many thanks
Thanks, Mark. Additional photos, especially of the other side would be helpful. I take it there's no SDFB trade in on these.
Good Morning - Production Units photos attached, Many thanks - Mark
Are you replacing the fuse in the attached appliance with a slug ?? nothing on your site mentions this.
As I understand it, it’s functionally the same as the SDFB, except with more limited user set amp choices. Sluggo is still at the component end.
Not to sure on that, there are no prompts to order the slug by size or type.
It doesn’t say it, but there has to be something in the component’s fuse holder.
G
Good Morning
This box works just like SDFB - so the answer is yes, you use this box with a Sluggo
The web site work is going on daily for all three new products - great catch
Comes with Super Sluggo Free of Charge
Many thanks - Mark
I can confirm that you need a sluggo with the Infinity as well.
Have had mine now a couple of days. Has transformed my amp so far. I wonder if it has more positive effect on amps than lets say a DAC?
  • Love
A
All correct.
We had an End User that wanted 5 amps - he ended up using FOUR amps with great satisfaction. Spot On re Sluggo
Thanks - Mark
Those Prompts should be there tonight according to ACE - it's been quite busy for him - he works in a different Time Zone as he is in the Philippines
Ace does our Social Media, Site work and Intl Sales to Distributors
Many thanks - lots of email mirroring your comments :)
Best wishes - Mark
Videos would definitely help your customers to decipher the differences between differing products.
For example - I am still struggling to know the difference between your infinity fuse and the SDFB (if any, other than outer box design/size). I take it that one is user adjustable and the SDFB is factory set? Or am I way off on this?
Clearing the air and explaining things in a very precise way (without disclosing proprietary information) can help clear up some of the confusion, that I honestly think is holding some of your sales back.
Tom
From what I can see, It looks like the Infinity fuse box will also need either a pigtail or an adaptor to use with a component. I also don't see an option for this on the website when I last checked yesterday. Can anyone confirm that the Infinity fuse box does indeed require either a pigtail or an adaptor for connection to a component, and if so, is an adaptor on the way soon?
