Capacitor Question
As others have suggested, I think your results are likely to be much better than your theoretical 40% and also much better than their 20% guarantee wrt matching. The difficulties in designing and building a capacitor to an exact number should be the same for both of them if you order them, and they are built, as a pair. So if one is 15% high, then the other one should be 15% high as well.
I would ask Dueland if they agree with this logic, and if +/- 20% works for you so long as they are a matched pair, I'd order them.
Jerry
Do you actually need that kind of tolerance? There might be other ways. I personally would first try a version of the filter with readily available caps. Only if that gives the sound results you are looking for go for higher quality caps. Since (I assume) you are building up the filter yourself or have it build up by someone. You could get the caps you are looking for. Then measure them and then adapt by varying the resistor value to get the desired corner frequency. Much simpler than custom ordering the caps in the precision you are looking for.
Reactions: aLLeARS
Why not go for silver mica capacitors? Tolerances are as low as 1-2%
I would stay away from silver mica. The tend to be “hard” sounding from my experience.
How did you use it as a bypass or as the only capacitor in the signal path? I'm asking for a friend.:p
I tried to custom order 2,700pF and 3,000pF capacitors from Duelund, from its CAST copper line, for a DIY high-pass filter.
Duelund says it cannot guarantee each capacitor any closer than 20% to the actual value requested. In theory I could have two capacitors that are 40% apart in value! I think this is ridiculous.
Who makes a high quality high-end audio capacitor with values of 2,700pF and 3,000pF and some semblance of consistency?
Thank you.
Try to locate some Russian Milspec Precision Teflon caps
I have seen down to at least 5% tolerance
Reactions: DasguteOhr
Hello Thomas,
Thank you for your advice.
I understand that methodology, but I don't want unnecessary components in the
signal path.
Reactions: bonzo75
Jerry
Or what about ordering four of the same value and just having them figure out which is the closest matched pair?
Reactions: Carlsbad
Hello Thomas,
signal path.
I don't understand? You want to introduce some sort of filter. I did not suggest any 'unnecessary components'. Also: You already have many capacitors in the signal path some of them some big ugly electrolytics. Worse : probably several of them in series. So what is the fuss about this particular capacitor? I merely suggested a way to cope with the tolerances
Thank you. I must've misunderstood.
I'm not using a resistor, so I thought adding a resistor would be a new and unnecessary component.
You have a schematic of this filter?
In a tube amp you need only change first couple cappacitor for input tube or add when not there.If I remember correctly the cutoff frequency was 200hz.
47kohms input needs 0.015uf cap ~220hz
Ok I (as some others it seems) understood that you want to implement a filter. If so there is a resistor at play. Anyways it would make more sense to first get a better grip at what is the intention before chasing boutique components. There might be a super simple solution to this. And as I pointed out: Why worry so much about this one capacitor if there are many others in your system which are obviously not Duelund and do not seem to bother you
In a simple first order high pass filter my understanding is that only a capacitor is needed because the input impedance of the amplifier functions as the resistive load.
You are totally correct about this! But you are minimizing audiophilia nervosa: I want any additional components to be fancy, high-quality components.
