Popularity of a step-up transformer?
The Cotter is a musical force, I still love it. The Technics impressed me back then with its airy, powerful sound. When John, a friend of mine, came around the corner in 2008 with Silvercore and said, "Listen to this with the Dynavector XV 1s," it was done. I've never used any other transformers again. It's so much better. It's hard to describe the dynamics and openness. It's like a window has been opened in the music. I heard things I've never heard before. Compliments to Christof Kraus. Very, very well done. All mine diy phonostages use silvercore suts.View attachment 153387
I'm very interested..I'm looking for a sut that will make my Dynavector XV-1s sound great..could you tell me about your experience with the xv1-s and the various suts...which silvercore transformers do you use..? which model are they..? thank you very much
Back then we had the Ortofon T 100 and the Kiseiki MCT 1 for comparison, both are pure silverwire SUTS. The model is called Silvercore MC Pro 1:20, bought back then for €1.7k, but today it's unfortunately much more expensive with a nicer cabinet. The XV 1s has a bit too much meat in the fundamental tone of 150-400hz. But that makes it fatter, especially when you have deeper male voices on the recording. I have to say right away: if you particularly like that, the Silvercore is the wrong product. It cleanses up the entire sound. It plays more dynamically and balanced across the entire frequency range without tipping into analytically sterile territory. Back then I used Dynavector with the setting 1.96 g VTF and anti-skating~ 0.4-0.5 g, measured at LP height.
Ask here
out of stock on homepage
Normally it (anti-skating) should be around 0.18-0.23g if you’re measuring laterally. 0.4-0.5g is too much.
This is an estimate from me I adjust it by ear. Sounds good, that's important.
I don't make rocket science out of it. Screw complete out=0
I think it’s better if it’s been rocket science cause almost all areas are laid out properly. Cartridge setup and particularly anti-skating contains more uncertainties in my opinion.
Reactions: Bonesy Jonesy
The procedure takes 30 minutes. Determine the mounting distance. Insert a 1.5mm Allen key through the hole in the Raven 10.5 headshell onto the Thorens spindle. Set the VTA parallel to the platter with LP, VTA 90% of the manufacturer's recommendation. Then, at the zero points of the arm, align the cartridge with the cantilever. Ready for listing. Adjust the VTA and anti-skating by ear.
Photos step by step
VTA , Azimuth & settings geometricaly zeopoints( zoom in) of tonearm20250629_160546.jpg
So far, no one has complained when I installed and adjusted the cartridge or heard my system at home.easy install with a tw 10.5 tonearm thats why i love the tonearm.
P.S
The VTF can be adjusted according to the cartridge output voltage. Only when the cantilever is in the vertical middle position (coilscross) does the maximum output voltage occur. A true RMS millivoltmeter and a 1 kHz test tone are required.
Reactions: Lagonda
I do own both.
The Technics provides turn ratios of 1:10, 1:16 and 1:40 what let the cartridge see 470Ω, 184Ω or 29Ω. The Cotter/ Verion MK1 can be configured for various turn ratios with 1:20 (cartridge sees 118Ω) beeing the most common setup.
Consequently they need different cartridges to show what´s really in them.
I just joined this forum to say that you are my hero sir! I have owned an SH-305MC since ordering it directly from Japan in 1982 and have never seen reliable information about its step-up ratios, despite numerous attempts (every few years) to find something. I just happened to do another search earlier today, expecting to find nothing as usual, and was led to your post from just a few days ago.
I must say the ratios you describe are close to what I suspected but it’s still wonderful to see them in print. Respectfully, how did you obtain this information?
I like switching cartridges in and out, so it's hard thinking of any one unit, but I came across this Zesto 'adjustable" SUT?
Anybody with experience?
I have no experience with the Zesto but in principle I am opposed to switching especially for such low voltages like MC cartridges. Plus, at that price level I would prefer a well-established SUT like Dave Slagle’s transformers.
Adjustable load is achieved by parallel resistors with the secondary winding what actually is a good idea but turn ratios are unconventional. I´d rather expect 1:20 or even higher turn ratio for low output, low impedance MCs to make them sing even when combined with adjustable load functionality.
very often I have the discussion, which step might fit the best for a dedicated cartridge and if a used step up
from manufacturer xyz would do it as well.
So I like to share a list of step ups with their base data in terms of gain, ratio and recommended cartridge coil resistance:
(this list can be used as well for new step ups, as long you know ratio or gain of the step up)
Manufacturer
ModelGain(db)X FactorNatural ImpedanceRecommended Impedance
OrtofonT52620,0118,13-40 ohms
T103239,829,72-4 ohms
T10 MK22825,174,52-6 ohms
T203239,829,72-4 ohms
T20MKII2825,174,52-6 ohms
SPU-T1002620,0118,11-6 ohms
T10002620,0118,12-6 ohms
T20003556,214,93
T30003031,647,02-10 ohms
Fidelity ResearchFRT-43135,537,33
2620,0118,110
2517,8148,630
2010,0470,0100
FR XF-13031,647,04-18 ohms
FRT-32620,0118,130
3135,537,310
XG53450,118,7< 3 ohms
2620,0118,13-18 ohms
2212,6296,518-40
X1-M3031,647,04-18 ohms
X1-H2517,8148,619-40 ohms
X1-L3663,111,83
DenonAU 32031,136363
20,01047040
AU 34030,433433
20,01047040
AU31020,01047040
AUS122,3132783-40 ohms
AU300LC20,01047040
Audio TechnicaAT700T3450,118,73
2620,0118,120
2314,1235,640
EARMC429,53052,23
27,62481,66
25,118145,112
20,010470,040
MC329,530524
26,02011812
20,01047040
SupexSDT 330028,526,666,42-10 ohms
BrystonTF122,513,3264,35-35 ohms
16,56,71052,240-250 ohms
NakamichiMCB10026,020117,52-20 ohms
SonyHA-T1102620117,53 - 40 ohms
If you use a step-up transformer do you then have to use the MM input of the phono preamp?
Manufacturer
T20003556,214,93
2620,0118,110
2517,8148,630
2010,0470,0100
FRT-32620,0118,130
3135,537,310
2212,6296,518-40
X1-L3663,111,83
20,01047040
AU 34030,433433
20,01047040
AU31020,01047040
AU300LC20,01047040
2620,0118,120
2314,1235,640
EARMC429,53052,23
27,62481,66
25,118145,112
20,010470,040
MC329,530524
26,02011812
20,01047040
I´ve shared these kind of data for more vintage SUTs combined with calculations for parallel resistors on secondary windings for adjustable load with a google table already many times before
