Any listening impressions with this DAC?The new D900 model is interesting: Delta Sigma 1-bit DAC without Delta Sigma DAC chip. Similar to R2R DAC. Never see such thing before 32bit split in 32 x1bit modulesView attachment 152914
Thanks
No sorry , this dac totaly new on the market for a week.Any listening impressions with this DAC?
Thanks
Curious about the first impressions…No sorry , this dac totaly new on the market for a week.
How much is it?
As long as you don't go below -40 dB on the digital level, you'll still have 16-bit resolution on modern devices. So don't use it as a complete volume control for the system.I think the moment we see numbers below full gain we think we are loosing sound , this I feel
Is untrue and is needed to get better tone and decay.
most any preamp has a sweet spot in its volume knob to get there we can in most cases adjust the input gain
a dac to me is the same and it’s digital input gain is how we adjust to find the sweet spot of a dac.
each track or album is louder or lower and using the digital output volume is used to adjust the tone.
Each bit represents 6dB of headroom, which means a 32-bit machine, as most are currently, has a range of 32x6 = 192dB.As long as you don't go below -40 dB on the digital level, you'll still have 16-bit resolution on modern devices. So don't use it as a complete volume control for the system.
I feel your completely correct it's used only to make the system tone seem rightAs long as you don't go below -40 dB on the digital level, you'll still have 16-bit resolution on modern devices. So don't use it as a complete volume control for the system.
Even a CD player I feel has the same effect .Each bit represents 6dB of headroom, which means a 32-bit machine, as most are currently, has a range of 32x6 = 192dB.
CD can resolve 16x6 = 96dB. When playing CD quality, you could drop the level to (32-16)x6 = -96dB before impacting the resolution.
To play a 24-bit file at full resolution, you could drop the level by (32 - 24) x 6 = 48dB.
That depends on how many bits your music has or whether you're upsampling. You just showed me what your DAC is technically capable of. Not what it does with music.Each bit represents 6dB of headroom, which means a 32-bit machine, as most are currently, has a range of 32x6 = 192dB.
audiophilestyle.com
No. It really doesn't. I'm not sure why you think it does.Yes, it does mean that…especially compared to real life…
Because it means this inherently by definition.No. It really doesn't. I'm not sure why you think it does.
A dac that doesn't soundstage as deep as another, isn't by definition, flat.
A dac that isn't as dynamic as another, isn't without dynamics.
Fewer tonal colors isn't grey.
Lacking in one area compared to another DAC, doesn't mean that quality doesn't exist in the DAC or that it's all the way to the extreme.
Something that doesn't soundstage deep or make 3D images is...well Flat
Something that lacks dynamics compared to another DAC, which is better capturing what is on the recording is by definition compressed
Something that has fewer tonal colors is by definition grey. From the Mirriam-Webster dictionary: c: dull in color
it doesn't mean the Topping is the MOST flat, the MOST compressed or the MOST grey sounding DAC, but it does fit that description compared to superior DACs.
