Dev betas tend to add features over time. So we will see. Maybe there is a more deeply buried option, say a per app setting.
Overall.. Pic and sound are the same quality wise so far. BUT huge bugs. Skipping can produce wierd sputters and dropouts. So ff and whwn you stop and play, it can be sputter. Lipsync was WAY off at one point. Frame rate issues with dolby vision and match frame rate on, this judder only occurs to the menus, material is fine.
Ive seen it loose cthe hardwired connection with even a reset not bringing it back. It saw the wired connection as soon as i hooked to wifi. It connected to wifi and then immd went to wired.
REMEMBER Betas can BRICK your ATVX. DONT DO BETAS.. And Development betas, your asking to get bricked. NEVER do dev beta or beta ! No one can unbrick them.
I am always testing betas. If i brick mine i can replace it.
I did brick one not long ago. I was on a public beta and was playing with a Lumagen. I forced the ATV into a weird HDMI video spec and that was that. On boot now it just has a front LED flash sequence and never boots or even turns on HDMI.. So it CAN be bricked. Be warned. Betas are bad.
