The actual written review Dean did is posted on Positive Feedback. There is more coming from them, this is the technical review.
I have a JVC NZ8. I just received my apple TVX a few days ago. Im having a hard time getting a good picture. SDR seems to be OK, but anything else is not sharp. Can I ask what settings you have on your NZ9 and your apple TVX?
I’ll happy to reports that after many hours and experimentation I have my Apple TVX performing as I hoped. I think over 4 days I tried just about every combination of settings. Ultimately on the NZ8 the initial installer had the screen gain set at 1.2. I adjusted it to 1.0 and everything came into line. Picture is great, color is great, and sharpness is great!Make sure to send him a PM as well![]()
Slightly off-topic but does anyone know what the difference between 16 bit and automatic is? Automatic sounds better when connected via toslink to external DAC and Airplay.
My ATV is the older version, no worries, like I said it was off-topic.Okay - I'll bite. Are you talking about a setting in the AppleTV-X system or somewhere else? I don't believe AppleTV with 4k supports toslink, which probably underlies my confusion.
And although I'm not the guy to answer, perhaps someone with the right experience can get you an answer with a little more info...
Can someone post the recommended Apple TV-X settings or post a link to them? I just got a new projector and the 4kHDR picture is so dark compare to 4KSDR. I forgot which setting is recommended and also what to do with match content.
Thanks.
I feel you my friend! Took me a week to wrestle my 120 custom Japanese Takachi cases for our new JS-4 through customs. I am waiting to see the tariff bill.It SUCKS to me a small business right now based in the US.
Ooooo....I feel you my friend! Took me a week to wrestle my 120 custom Japanese Takachi cases for our new JS-4 through customs. I am waiting to see the tariff bill.
You should call me though as I have some ideas for you with regards the R-core situation.
I totally hear you Chris. I've been thinking I need to order your Switch-X / WiFi-X, even if it can't be fulfilled for a couple months.
Thanks for letting us know...
