Best question in this thread for a VERY long timeWhy would you need more than 60 - 90 mins?
marathon preparation or iron man?Why would you need more than 60 - 90 mins?
Nothing has changed. I have been posting about the improvement in resolution over the Jadis ever since I got the Italians.So what changed? Under what configuration did you hear this that you had not heard before
Good question. Without a trainer I waste a huge amount of time watching the cannibal documentaries in between sets.Why would you need more than 60 - 90 mins?
Having owned and currently owning amps with 6C33c output tubes, I can say that I have not had any more issues with them than other tube amps. I have also owned OTL monos (Silvaweld) that sounded amazing but heated my room unbearably.I researched the big Joule Electras a long time ago.
I'm sure I would love the sound. But I would not be able to relax with the ever-present insta-blow risk.
When you heat the cathodes in parallel, the heating current is over 60 amps for both monos... it just gets hot in the room. I didn't have any failures with the 6c33c either, but selecting them so that they maintain a stable quiescent current is more difficult.Having owned and currently owning amps with 6C33c output tubes, I can say that I have not had any more issues with them than other tube amps. I have also owned OTL monos (Silvaweld) that sounded amazing but heated my room unbearably.
Is the edge there if you lower volume 3db ..?Nothing has changed. I have been posting about the improvement in resolution over the Jadis ever since I got the Italians.
I'm still hearing that bit of edginess/brightness. But even with that bit of edginess and brightness -- which I'm still hoping goes away naturally from burn in or remedially from the Zobel network idea* -- I like the improvement in believability.
*I ordered a pair of resistors and a couple of pairs of capacitors. I'm very skeptical about Ralph's hypothesis that only a 1 or 2dB rise in amplitude is causing the edge/brightness, but it's worth a try.
Yes, I had the same monos! Kept tripping my circuit breaker on startup…that was also quite annoying.When you heat the cathodes in parallel, the heating current is over 60 amps for both monos... it just gets hot in the room. I didn't have any failures with the 6c33c either, but selecting them so that they maintain a stable quiescent current is more difficult.View attachment 150029
I hate to say it, but what are you doing with power? I was absolutely shocked when I changed a duplex from Hubbell to Furutech and tossed the Ching Cheng cables. I don't like tin wire. The stuff you used is fine stranded tin coated wire. Its such an unknown.Nothing has changed. I have been posting about the improvement in resolution over the Jadis ever since I got the Italians.
FWIW: I usually do not bet against Ralph.Nothing has changed. I have been posting about the improvement in resolution over the Jadis ever since I got the Italians.
If the amp is unstable and going into oscillation, and having IMD… then a Zobel network is a dandy solution.
Your previous post to this, the one with the exercise comment, made it as if you just heard something that made you select the master sound over the Jadis.Nothing has changed. I have been posting about the improvement in resolution over the Jadis ever since I got the Italians.
Why would an amp go into oscillation on a ribbon speaker? Ribbons behave the closest to a pure resistor of any loudspeaker type. Clarisys even uses low order crossovers, so the reactance in the crossover also should not be very bad. An electrostatic speaker is entirely different…it is highly reactive (basically a big capacitor) and can drive marginally stable amps nuts.FWIW: I usually do not bet against Ralph.
Many people can hear 1/4 to 1/2 a dB, so 1-2 dB would be readily apparent even to people than don’t care a damn and who don’t think that sound matters. For people that listen to stuff, it would stick out, as the Australian say, “like dog’s balls.”
I haven’t seen the graphs of the impedance of the speaker.Why would an amp go into oscillation on a ribbon speaker? Ribbons behave the closest to a pure resistor of any loudspeaker type. Clarisys even uses low order crossovers, so the reactance in the crossover also should not be very bad. An electrostatic speaker is entirely different…it is highly reactive (basically a big capacitor) and can drive marginally stable amps nuts.
I think I mentioned before that Don and Ralph are amongst other “Subject Matter Experts” (SMEs) in this stuff.What is the basis for your hypothesis that the amp is unstable and oscillating into a 4.0 to 4.8 ohm resistive ribbon driver load out of its 4 ohm tap? In other words, why would this be?
I am skeptical about this for any normal loudspeaker cable.One can have an amp connect to a speaker and everything is just dandy.
Then they can change only the speaker cable, and that same amp and speaker now goes into oscillation.
