Thank you very much for information.
I did not have Lamm ML2 but Romy think the bass of Lamm ML2 is very good
Lamm measurements in stereophile :
Sidebar 3: Measurements Following Vladimir Lamm's instructions, I let the ML2.1 run for an hour or so before I checked the output tube's plate voltage and current. While the voltage was correct at 175V DC, the current was a little high at 0.35A. I adjusted it to read exactly 310mA, as...
www.stereophile.com
As you see the bass response of Lamm ML2 is very extended .
I have checked many stereophile measurements of different tube amplifiers but non of them was as good as Lamm in bass extension.
I hope you have a good description for this.
I do. This amp uses several techniques used to extend bass response.
The first, which is more common in modern SETs, is to make the output transformer quite a bit larger than needed, in this case much larger than needed for a mere 10-15 Watts.
The second is to sacrifice high frequency bandwidth a bit, IOW the transformer is optimized to favor low frequencies over the highs. Most SETs are the other way 'round, since the speakers they are often used with don't have much bottom octave response.
Finally negative feedback is used, which makes the Lamm unusual in the pantheon of SETs. Feedback helps linearize bandwidth at both extremes.
But the measurements are incomplete.
A more telling squarewave analysis would have been to use a 20Hz signal rather than 1KHz (FWIW our OTLs are full power to 2 Hz which allows for no squarewave tilt on a 20Hz squarewave).
One of the more telling measurements is full power bandwidth (not seen in the Stereophile measurements), which in most tube amps looks
quite a bit different from their 1 Watt bandwidth!! If there is a deficiency of inductance in the output transformer to make bass, it's less likely to show at lower power levels. If the Stereophile measurements had shown distortion vs frequency, an obvious rise in distortion would be noted at lower frequencies approaching the cutoff frequency. This is a good way to tell if the output transformer has sufficient inductance.
If you'll note, the bandwidth measurements are made at 2.83Volts (1 Watt into 8 Ohms). Bass is the region where most of the musical energy resides and so is where most of the amplifier power is used, so if you clip an amplifier, its likely that you will be doing it with some sort of bass notes. Thus, finding out what the -6dB from full power bandwidth and the full power bandwidth is will tell a lot more about what is going on. I seriously doubt this amp can make full power at 20Hz! But having had this amp in our shop, I can also say it does play bass better than most SETs (which wimp out), when bass heavy tracks are thrown at it.
But if you compare this amp to one that
can make full power at 20Hz, then you'll see (hear) what is going on.
