Saving for retirementWhy don't you?
I can recommend a few budget components in the meantimeSaving for retirement![]()
I was going to ask you a question about how this works with the Pulsar but it sounds like you can configure it as an HQPlayer NAA Endpoint. Does this 1) result in an improvement in sound quality vs. just using Roon with an Eversolo A8 as the endpoint outputting over I2S to the Holo May KTE, and 2) does it equal or exceed the sound quality using the Sense App with the Pulsar no Roon? Thanks.I also have Pulsar/Holo May. You could spend $1,000 on a Mac Mini and HQ Player and use the HQ Player endpoint with Roon as controller.
Tim, at around 7000 I have more than enough![]()
Either a Aurender W20SE or an Antipodes K - 50.....Both of which are on my short list for next purchase....
So have I, also the battery power supply is very interesting…..Been reading good things about the W20SE.
