I get what you mean. I don’t think it is uncommon for some drivers to be wired in reverse. It’s the phase angle of the signal coming out of the crossover that requires it. All the end user can do is wire one of two speakers backwards or both backwards. My DAC sends out an inverted signal so they recommend reversing the leads on the speakers. Since I also use a phono preamp I simply hit the Invert button on my Line Stage preamp when using the DAC.Ah no…
I not sure we both understand what those graphs are trying to show.
Loudspeaker step response measurement and explanation
Learn how to make a loudspeaker step response measurement using ARTA. The data is extracted from the impulse response.audiojudgement.com
Earlier in the thread people were talking about how much getting the polarity right matters.
There is either timing problem or a phase problem with the Alexx that, while they are wildly more expensive than the Quad ESLs, their performance on this particular front is not as good.
Actually the negative section in the snaggletooth indicates that the midrange is going backwards, rather than forwards.
That either matters, or it doesn’t… but someone mentioned that the hooking up the wires correctly was step #1.
While the Wilsons also look more expensive in terms on construction, I’d take the Quad ELS myself just based upon measurements.. because in this case the ESLs are worth the money.
I have heard speakers before that made me feel disoriented or just the sound stage imaging seemed twisted around. Mostly back in the 80s. I wonder if that was caused by out of phase drivers. And not by design but by built in defect- as in someone may have wired a driver in the wrong way at the factory.
And frankly, I do not hear much of a difference when I switch between inverted and normal on my preamp when playing the DAC. I should try actually reversing the speaker wires maybe to see if that is more audible for me.
