Interesting . . . but there's no way those amps were properly powering the Apogee drivers (unless maybe at low volume in a small room).
They weren’t, even biamping with NAT transmitters was under powering the Grands
Yeah funny how EL34s sound pretty rich in triode mode. That said, my Ayon Spark sounds a lot better than any Class A EL34 in triode that I have heard...Yes, i have el 34 ( two)push pull in triode mode they sound close to 6c33 tube. The set amp a little more voluminous bass that all for ears.both 16 watt output power
Nonsense! The SE2SE sounded a lot better than the Transmitters anyway. Plus all the Grand active electronics, which were not being used when we did the CAT vs. NAT comparison, are quite detrimental to the overall sound of the Grand. It sounded best when used with a Diva passive crossover (rebuilt with premium parts) and an Audio Research active 2-way tube crossover to go between the sub and panel. Perhaps crude but far more effective than the actual Grand electronics.They weren’t, even biamping with NAT transmitters was under powering the Grands
Highly doubtful with only 600 watts dissipation at idle for reasons I just described...and I didn't even account for the small signal tube contribution and losses in the passive parts. Plus they say the amp goes up to 1500 watts dissipation at full power...a Class A amp would not change power draw over the full power range and this one obviously is sliding all the way up to full power.In fact, considering the definition of class A the Siegfried II it is class A up to 90W - it is an high bias tube amplifier.
Class A / class AB is a poorly understood affair, as in practice it depends a lot on the impedance of the loudspeaker load.
A friend of mine had some MB-450s for a while and although they were pretty rich sounding at times, they didn't sound remotely like a SET. Pleasant enough though...I am certain that my MB-750s -- which I had for 18 years -- had more of an SET flavor than the Siegfried IIs.
If I get Jadis JA120s I will use EL34s.Yeah funny how EL34s sound pretty rich in triode mode.
"Breath of life" and "liquidity" and transparency on vocals in the midrange.How do you define SET flavour?
If you must go push/pull then get something like the VAC Phi 70 used, if you can find them or the new Thrax 300B amp that is all 300Bs! To my ears, the best sounding Jadis I heard was their relatively affordable Defy 7 mkIII with siltech wiring...that made a nice sound!If I get Jadis JA120s I will use EL34s.
I can show you anytime, just come by. While you drink a coffee, I'll turn down the idle current of the EL 34 so that the K2 dominates. Then you'll see how similar the two amplifiers can sound. Unfortunately, I've told you what the difference in sound is, you'll immediately recognize it.Yeah funny how EL34s sound pretty rich in triode mode. That said, my Ayon Spark sounds a lot better than any Class A EL34 in triode that I have heard...
WHich 6C33C amps are those?I can show you anytime, just come by. While you drink a coffee, I'll turn down the idle current of the EL 34 so that the K2 dominates. Then you'll see how similar the two amplifiers can sound. Unfortunately, I've told you what the difference in sound is, you'll immediately recognize it.View attachment 144216
Thank you, but I'm happy with Jadis.If you must go push/pull then get something like the VAC Phi 70 used, if you can find them or the new Thrax 300B amp that is all 300Bs! To my ears, the best sounding Jadis I heard was their relatively affordable Defy 7 mkIII with siltech wiring...that made a nice sound!
A good hybrid, like a Sphinx Project 14 or 16 (true Class A) or the Conrad Johnson EVO2000 (sounded great on Duetta Signatures) would probably be preferable sonically to most PP tube amps.
I have never seen or hear VTL describe the Siegfried II this way.
Yes; relatively easy to drive, as it is a pretty flat resistive load
Okay! I did not know the NAT SE2SE mono is 70 watts!NAT at least 70 watts...more than enough in a normal sized room...and not just for low volume. It worked and worked very well.
On transparency I agree the Siegfried II wins.Well, I disagree with you on the MB750 versus Siegried II. I also owned the VTL MB750 before owning the Siegfried II. Although I do not know what means "Breath of life" on vocals, in my opinion the Siegfried II wins in "liquidity" and transparency on vocals in the midrange by a significant margin over the MB750,
It’s a PSETOkay! I did not know the NAT SE2SE mono is 70 watts!
Is NAT SE2SE mono PSET or push-pull? (Must be push-pull?)
