Perfect sense Audio
Dealer - Perfect Sense Audio
The B.audio B DPR One EX is a very natural sounding one box solution with a small footprint
I can confirm that. A great product and company overall.
/ Marcus, www.perfect-sense.se
@Christiaan Punter reviewed this positively, I wonder if it's worthy of consideration with a 20K budget?Watson audio: Madison LE
That will be snappedOK, then the OP should consider Taiko Olympus with the in-built DAC, the perfect one box solution![]()
Hi,
Your K50 is also server, I wouldn't drop this kind of feature so quickly.
have owned Cary DMS 500, and DMS 600 in the past, they are nice but far from "big boys" league. Owning MSB Premier DAC and Luxman D10x, feed buy Melco server, the first one (the MSB) is the better sounding.
I have heard the Grimm M2 several times, while its great, to my taste I still prefer the MSB, even When fed from render and not the ProISL module.
Someone here mentioned the Watson audio: Madison LE, its quiet surprising little unit (the company used to design the DAC board that CH used in its receivers\dacs before CH bought it)
Out side the MSB Premier you might check Esoteric N-01XD, a second hand Linn Klimax DSM or the Naim ND 555.
For me, in terms of sound, the MSB is closer to an analog experience compared to the Grimm. My reference for sound is always my turntable, the Brinkmann Balance.I'm considering an MU2. Would you mind expanding on what you liked about the MSB over the Grimm?
To the OP, I would recommend the Linn AIOs as well. Modular and upgradable when needed. Sound very nice too. The dCS Bartok Apex is another option.
It’s more engaging, it have better instrument separation, more organic sound, more realistic decay, and in my system the timbre sound closest to original instruments sounds.Thanks. Could one describe the MSB then as warmer with better flow and engagement?
I will second that.Watson audio: Madison LE
Well at least with the 111, Burmester remembered to include a volume control knob - they forgot it with the 151I started the one box solution with a burmester 151mk2, fabulous unit and hard to beat for the money, sold it, moved into the 111 reference, does everything right IMO
