The Vandersteen speaker setup uses a jig attached to the front of the cabinet with a built in laser.
Pick an orchestral side where first violin starts on left, then orchestra joins in (e.g. Scheherazade 4th movement). Violin will clearly start on right if channels are reversedI am curious. How do you find rooms with the channels reversed but the exhibitors don't know it?
Jim Smith’s book inspired me to buy a laser measuring tool, which I now use to position my speakers.
I still start with a measuring tape, but for fine-tuning, I rely on the laser tool to ensure everything is perfectly precise.
When I had Martin Logan’s, 10 years ago, I got a lot of ML owners telling me to use a laser tool, so bought one. I had also seen a surveyor use it during a house purchase to confirm floor plans.
ML is very specific about toe in, and with electrostats placement needs to he quite spot on due to very narrow listening spot. Both toe in or straight and vertical raking needs to be accurate.
With good horns, which have a broader listening spot, and large dispersion (e.g. Altec), it won’t matter as much
Thank you for sharing your experience with Martin Logans and your Altec. For me, the laser tool has proven easier to use than multiple measuring tapes, as the laser line remains perfectly stable while I move around the speakers to make adjustments.
I have direct experience with horns through my best friend who owns Avantgarde Trios. When we used a laser tool to precisely align the horn sections at height and direction, the results were noticeably superior and the setup process was much more efficient compared to using measuring tapes.
While I respect that different methods work for other people, I've found the laser tool to be invaluable for precise speaker placement across various speaker types. It's simply a matter of choosing the tool that works best for your specific situation.
What if room is not symmetrical, and there is a pillar or something else behind one speaker when at same distance from your earsThe reason to use a laser is to get the two speakers the same distance from your ears.
I haven’t faced either situation. But I think it would still be optimal to have each speaker the same distance from the listener even if this resulted in different distances to wall surfaces in the room.What if room is not symmetrical, and there is a pillar or something else behind one speaker when at same distance from your ears
I do the same thing! That said, regardless of the speakers, I almost always have the tweeters “grazing” the outer edges of the listening chair back.The laser is a starting point. Careful listening and fine tuning speaker/chair position is the final step.
I also use the laser to aim my speakers with a yardstick placed on the back of my listening chair. That too is a starting point but the laser helps to make the fine tuning with precision.
There’s really no reason to fuss with measuring tapes given how inexpensive the lasers are these days. Way easier to get accurate results, in my case 1\16 of an inch at times, although reproducibility is an issue!Thank you for sharing your experience with Martin Logans and your Altec. For me, the laser tool has proven easier to use than multiple measuring tapes, as the laser line remains perfectly stable while I move around the speakers to make adjustments.
