New Reel to Reel Software Sources from UHA
I know the ATR-102 sounds great. I heard it playing several tapes with the most memorable being the Louis Armstrong "St. James Infirmary."
And oh, did I mention that the ATR-102 does 30 ips and can handle 14" reels? The Louis Armstrong tape was a 30 ips tape on a 14" reel. That was the first time and only time that I have seen a 14" reel and heard a tape playing back at 30 ips.
You're in for a real treat then. It only gets better! You need to hear 1/2" at 30ips on a Studer..... priceless!
Allen Sides at CES I think plays some 1/2 inch/30 ips tapes.
I'll have my 1/2" Studer at Newport and RMAF this year.
Unfortunately won't be able to make the Newport show :( Only so much time can get off work :(
Which Studer, BB :confused:
Sonny and I will be sure to drop by...will you attend? :cool:
Our A80RC that Ki did his magic on. Rene and I will both be there.
Excellent
Are you showing with Jonathan?
I'm contemplating arriving with some 1/4" and 1/2" reels...
Would your repro chain include an ability to process Dolby A tapes?
Your A80RC can go 15/30 ips, right? So, in addition to the different headstacks/blocks -- would different cards be necessary :confused: I'm not conversant with the A80-series :eek:
Thanks.
Thanks.
Jonathan will have some of our tapes. I think he uses his ATR-102 now.
I would need a Dolby A processor in the playback chain if needed.
Yes, our A80 will do 15/30ips. Ki did a complete rebuild of the cards. For another flavor, we can also use outboard pres.
