Per Jeff F recommendations to me, Since the tube heater circuit in series with both tubes, its important that both tubes are the same mfg and model type. Mix and matching could cause unforeseen circumstances on the heater circuit.With the ART88 would there be any harm to mix tube values in the "double triode" and "cathode follower" positions, i.e., 6922's in double triode and 7dj8's in cathode follower or vice-versa?
You didn't have any problems with these not being 7 volt heater tubes?These tubes are better then the supplied Philllps tubes. They add a denser low mid and midrange.
6922 / E88CC PHILIPS SQ NOS Gold pins
Ever thought about trialing the ART 88?I just called conrad-johnson, and Jeff immediately picked up the telephone. Jeff told me he currently has six (6) full-time employees -- so c-j is far from a one-man band!
Nope!Hope they finally addressed the negative polarity issue..
Hi!It’s also related to the fact that many dealers won’t trade for CJ,
Heres a big WOOF WOOF! to you Big Dog!Note: from GATS2 to ART88, I would sincerely believe the improvement is around the 15-20% if at all. The thing is, at this high level of performance, I wouldn't really term it as an "improvement," rather I'd say the two preamps just sound different.
G'day Ron mate, trust all is well at your end of the woods.Heres a big WOOF WOOF! to you Big Dog!
In what ways do these two preamps sound different to you?
Always enjoy your posts, RJ! Re: tubes in the ART88, I count only 4, 2 per channel. Do I need to brush up on my math skillsG'day Ron mate, trust all is well at your end of the woods.
Yes, comparisons on the GATS2 and ART88 are always a learning curve for me. Both very fine preamps (including the GAT S1). The most significant difference is that every CJ tube preamp uses SS buffered output stages. This also includes the original ART preamp (two chassis design) which I also owned way back during the years of having Apogee Diva's driven by CJ's Premier 8A monoblocks. BTW a legendary system, supremely well matched. I still miss it to this day.
Fast fwd that to few decades... and this is the first time CJ has used a full tube design in the ART88. It uses 6 tubes, out of which the last two pairs are used in its output stage and for impedence matching. There are no SS buffered outputs in the ART88, and it is true testament of a CJ all tube preamp that is top of the line! To me, it's the very essence of being top of the line, regardless of price.
As for the specific comparisons between the two, I've written a review of this very topic in an earlier post, can't seem to find it...
After going through my post, LL21 commented on the "amazing commentary"... I think he'll know where exactly my post is.
It was a lengthy audition, and we had few people to help out with connections because running back & forth to do this, is not an easy task when changing a vast array of interconnects between preamps. In order to keep the demo simple as possible, only 1 type of source was used, a SACD player by Esoteric K01-XD. Funny thing is, on the other day during the ART88 demo, ended up switching over to his TT rig and just sat there mesmerised until 3am! Gotta love tubes, TT's and Stats! Mighty fine tunes indeed!
During my travels to Spore, so I had the chance to audition (on two separate occasions) both units side by side in two systems. Owned by a close long term friend & dealer mate of mine, also has the ML Statements Evo-II's. He still uses the GATS2 with CJ ART108A's to drive his CLX's, and of course simply superb!!! The other system consists of the ART88 partnered with the ART300's in the Statements Evo-II's system, along with a very old pair of Infinity IRSV's (now parked into a different room, undergoing refurbs).
Cheers, and do enjoy those finest tunes!
That's a mighty WOOF!
RJ
I'm sorry I did not see your prior post myself, and I repeated the same question to you!Attn: Ron
Think I finally found it:
Aug 5 2024 post #57
That deserves a mighty WOOF!
RJ
Oh matey! That's 110% correct!Always enjoy your posts, RJ! Re: tubes in the ART88, I count only 4, 2 per channel. Do I need to brush up on my math skills![]()
No worries at all Ron, happy to answer that.I'm sorry I did not see your prior post myself, and I repeated the same question to you!
Do you recall if the Art88 is in any way more neutral or more "objective" sounding than the GAT S2? Putting the same question a different way, is the Art88 "cooler" or "warmer" in the midrange than the GAT S2?
Do you recall if the treble frequencies of the GAT S2 or of the Art88 were more extended or more pronounced?
Thank you!
WOOF WOOF!
Definitely shortens the lifespan, the cathode protection layer burns through more quickly. The real problem only occurs when the mains voltage is higher than the norminal voltage. A voltage constant device helps to protect the tubes.You didn't have any problems with these not being 7 volt heater tubes?
Oh! Didn't know that. 3% higher is definitely quite a wide variation... especially for precision tube gear. I'm thinking SS gear wouldn't be too affected but then again can't say for sure.Definitely shortens the lifespan, the cathode protection layer burns through more quickly. The real problem only occurs when the mains voltage is higher than the norminal voltage. A voltage constant device helps to protect the tubes.
Here in germany 3% higher than norminal voltage
230 volts is fixed in germany, most of the time 237 volts come here out of the socket. For old devices(220volt), I have a variable transformer so that I don't have to tinker with the device.Oh! Didn't know that. 3% higher is definitely quite a wide variation... especially for precision tube gear. I'm thinking SS gear wouldn't be too affected but then again can't say for sure.
Hopefully, you've got a way round to manage those voltage variations and enjoying those fine tunes!
Cheers, RJ
