Agree, it's pretty amazing how much the DC power cable impacts SQ!Recently picked up a used Plixir Statement power umbilical for my Melco N10 and I am utterly bewildered at the huge uptick in SQ.
For the Statement BDC, I use the schurter SMD_SPT gold plated fuse 20mm x 5mm. The spec is 3.15T (3.15Amps time lag type) as the standard fuse.For all fuse recommendations, can the size and specs of the fuses successfully proven to work in the Statement LPS please be confirmed. Greatly appreciated!
Hi,Recently picked up a used Plixir Statement power umbilical for my Melco N10 and I am utterly bewildered at the huge uptick in SQ.
do you make the statement in a 9V/4A config? Not on the website.Dear Mr Vangelis. Thank you for the kind words on the use of the Elite BDC with the Weiss DAC 204.
I will just have to add we now have the Statement BDC 9Vdc version specifically to support the Weiss DAC 204 / 205. It is another step up over the Elite BDC in this application, from customer feedback.
Hi, The Statement BDC are made only in 6A versions. We make a Statement BDC in 9Vdc for the Weiss DAC and SOTM products.do you make the statement in a 9V/4A config? Not on the website.
Is it 4amp? Weiss recommends 2amp. Just want to confirm before I orderHi, The Statement BDC are made only in 6A versions. We make a Statement BDC in 9Vdc for the Weiss DAC and SOTM products.
Thanks.
James.
For the Statement BDC It is 6Amps. I believe Weiss recommends minimum 2amps.Is it 4amp? Weiss recommends 2amp. Just want to confirm before I order
It is my first Product Of the Year Award in a very competitive and major market space and I am very honored to get the award.
Hey CKKeung what Amp rating worked in your Statement BDC?Synergistic Research Master Fuse : a reliable choice.
Firstly, the Plixir Statement LPS is in another league (with Ediscreation Firebird and Zayin Audio SupraReg LPS). Much better than the older Elite Series.I have an Elite BDC and I found Audio Bacon’s review to be spot on.
There is a silvery tone and a bit of dryness in my system (just like Jay @ Audio Bacon observed).
I’m curious, does the Statement BDC exhibit these same traits?
I’m using Plixir statement DC cable.
Not at all dry. Signature wise, the Statement BDC is definitely more musical.I have an Elite BDC and I found Audio Bacon’s review to be spot on.
Please include comparisons to the Statement PLiXiR BDC in your review.BTW I will write a short review on Zayin Audio SupraReg LPS soon.
It's my favorite LPS currently.
Hi CK,BTW I will write a short review on Zayin Audio SupraReg LPS soon.
Hi Opabin,Hi CK,
You have provided many interesting and helpful comments about your favorite router and switch power supplies. (Still waiting for the Suprareg review!) If the Zayin Audio Suprareg has supplanted your former favorite Plixir Statement LPS, how does its sound character differ from the Plixir? What are the advantages that helped the Suprareg win your ultimate favour?
A new fuse alternative with amazing performance - Swiss Digital Fuse Box (SDFB) from Vera-Fi Audio/Verafiaudiollc.com, totally worth checking out. I have two Statement BDCs using SDFB.Please don't forget rolling its fuse.
