Yes, well aware of that. I guess if I need to explain it, it’s not a joke.Jeff Fritz is an employee of Magico since May 2023.
His post is Brand Ambassador of Magico.
Haha. I haven’t listened to the S5 yet. But in general, regardless of what materials your woofers are made of, especially if you’re using the same material design, you can get lower harmonic distortions from the bass drivers if they’re bigger. So at the very least the S5 would have slightly cleaner, less distorted bass than S3 because of the upgrade from 9” to 10” woofers. And of course the larger woofers can move more air so it’ll be easier to play louder too. This is just taking about the woofer upgrade alone. Now whether that is worth the cost of trade in and upgrade is a harder question to answer.Curious if the S5 is worth the upgrade from S3
I could move air by adding my 2 rel 32'sHaha. I haven’t listened to the S5 yet. But in general, regardless of what materials your woofers are made of, especially if you’re using the same material design, you can get lower harmonic distortions from the bass drivers if they’re bigger. So at the very least the S5 would have slightly cleaner, less distorted bass than S3 because of the upgrade from 9” to 10” woofers. And of course the larger woofers can move more air so it’ll be easier to play louder too. This is just taking about the woofer upgrade alone. Now whether that is worth the cost of trade in and upgrade is a harder question to answer.
I’ve heard them both. I think the biggest thing to consider is your listening room. If you have a larger room, these larger woofers and incredibly damped cabinet will make a massive differenceI could move air by adding my 2 rel 32's
Maybe somone that heard both will chim in before I do another upgrade .
According to my dealer, my pair of S5s is on its way, having been shipped from Magico to New York. From there, they will be sent to my dealer in Israel, and then to me. If all goes smoothly, I should receive them by early December.Well thank you Mr. Mackay!
Got the call today that a pair of Magico S5 2024's is heading my way tomorrow (11/6/24). Will be traveling all next week so hopefully will have them available for install the week of November 18th.
Has anyone else waiting for S5's received an update on delivery?
That is good news indeed. Hopefully there will be no delays and you will be breaking them in soon. Looking forward to your first impressions. Cheers.According to my dealer, my pair of S5s is on its way, having been shipped from Magico to New York. From there, they will be sent to my dealer in Israel, and then to me. If all goes smoothly, I should receive them by early December.
Thanks! I’m hoping everything stays on track as well.That is good news indeed. Hopefully there will be no delays and you will be breaking them in soon. Looking forward to your first impressions. Cheers.
At first, I thought new S1 or S7? Can’t tell. I presume the other two speakers are S3 and S5.What could this be? Magico Instagram post says "Coming 12/02/24" View attachment 140448
looks like new S1 as the new speaker is smaller then the S5 and S3What could this be? Magico Instagram post says "Coming 12/02/24" View attachment 140448
Yes. Very interesting because the drivers (5" & 7") look like they're even better than M2. And the enclosure is built more like S1 than the S3/S5. But then M2 still has carbon fibre monocoque and even less diffraction with the baffle so...Haven’t seen this posted on WBF. Here you go…
MAGICO S2 PR — Magico Loudspeakers
www.magicoaudio.com
I can’t imagine the S2 being less than exceptional in its price/performance range. I know first hand how good the S3 is and now that I’ve had the S5 running in for 300+ hours in my room I can say with confidence the S5 is a step beyond the S3.Yes. Very interesting because the drivers (5" & 7") look like they're even better than M2. And the enclosure is built more like S1 than the S3/S5. But then M2 still has carbon fibre monocoque and even less diffraction with the baffle so...
Personally, even though many people said the new 5"/6" midrange for A5, S3/S5 sound better than the older midranges but I don't really hear it compared to the 6" driver of the M2. The 9" woofer of the A5/S3 definitely sounds like they have less distortion than previous generation drivers.
