I ordered the base version as I already have Grid and EMI Protectors and was told spending the extra $3K would likely not yield any audible differences. I’m very happy
Seems you obviously didn’t try various Furman models on your own?I was just surprised that someone with such a well sorted system would be using a old technology Furman. They are noise makers that congest the sound. Just removing if from the wall will reduce a whole lot of back noise into your electrical power supply. I suspected you would have a Shunyata or Nordost or something. Not a Furman.
| GRID PROTECTOR + POWERZONE | WITHOUT BOTH | ONLY WITH PZ | ONLY WITH GP | WITH BOTH PZ + GP |
| White noise/Hum | 0 | 20 | 80 | 100 |
| Background | 0 | 90 | 10 | 100 |
| Neutralness | 0 | 70 | 30 | 100 |
| Image precision | 0 | 80 | 20 | 100 |
| Soundstage depth | 0 | 60 | 40 | 100 |
| Soundstage width | 0 | 100 | 0 | 100 |
| Separation | 0 | 70 | 30 | 100 |
| Voice | 0 | 40 | 60 | 100 |
| Highs | 0 | 80 | 20 | 100 |
| Basses | 0 | 50 | 50 | 100 |
| Presence | 0 | 50 | 50 | 100 |
| Transient | 0 | 70 | 30 | 100 |
| Clarity | 0 | 80 | 20 | 100 |
| Airy | 0 | 50 | 50 | 100 |
| Detail | 0 | 80 | 20 | 100 |
| Unveil | 0 | 80 | 20 | 100 |
| Realism | 0 | 40 | 60 | 100 |
| Calm | 0 | 70 | 30 | 100 |
| Control | 0 | 80 | 20 | 100 |
| Engagement | 0 | 50 | 50 | 100 |
| 0 | 65,5 | 34,5 | 100 |
great summary LucaAs promised I’ve done my own homework!
In order to determine how impactful the Grid Protector is separately from the PowerZone I tested it in my system with a Furutech e-TP609E NCF power strip.
You may say that the power cord used in this test plays a fundamental role too, I completely agree but the Puritan cable (with Furutech plug upgrade) was the only one available as spare. Hence… let it be!
Obvious disclaimer: here below is the results in my room, in my opinion, to my ears… bla bla bla!
Before starting listening I left the GP detached (both cables) and with antenna unscrewed at least 6 hours.
Having said that I tried without both of them first, just the Furutech power strip in use and, believe me, I really don’t want to do that anymore: I was suffering so much hearing my system sounding without life, period!
Then I plugged the GP into the power strip, checking the correct polarity (for all the EU Schuko afflicted) and set all the 3 switches as usual to 2 position.
The improvement was immediate and clearly audible, as expected. The reduction of the subtle hum from the amp’s toroidal transformer (mechanical noise from inside the chassis) was less significant than before, it takes probably more time to be affective as I’m used to hear.
But the experiment had other aims actually so I carefully tried to determine the amount of improvement compared to the one brought by PZ alone.
Here below you can find a chart with numbers that should better clarify my impressions. Assuming 100% the job done when both the PZ and GP are in use (and 0% without both of them) I tried to be more specific in order to have a better idea about the areas where the one is working more than the other.
GRID PROTECTOR + POWERZONE WITHOUT BOTH ONLY WITH PZ ONLY WITH GP WITH BOTH PZ + GP White noise/Hum 0 20 80 100 Background 0 90 10 100 Neutralness 0 70 30 100 Image precision 0 80 20 100 Soundstage depth 0 60 40 100 Soundstage width 0 100 0 100 Separation 0 70 30 100 Voice 0 40 60 100 Highs 0 80 20 100 Basses 0 50 50 100 Presence 0 50 50 100 Transient 0 70 30 100 Clarity 0 80 20 100 Airy 0 50 50 100 Detail 0 80 20 100 Unveil 0 80 20 100 Realism 0 40 60 100 Calm 0 70 30 100 Control 0 80 20 100 Engagement 0 50 50 100 0 65,5 34,5 100
Conclusions.
It took me a day of listening but I was impatient, I continuously felt the urgency to set back all as usual because it’s really hard when you miss something so appreciated, even if for a short time.
I can confirm my initial impression, the Grid Protector and the PowerZone seem to be a perfect marriage, they sound great alone but the magic starts when I have both of them bringing my system to a higher level. Call it pleasure, audio Nirvana or whatever you like. I for sure can’t live without them, both together I mean.
Hope that helps.
Now back to music (at its best), the weekend starts now!
Edit, Sorry, I forgot the PZ was Gryphon. I knew it sounded familiar.As promised I’ve done my own homework!
The improvement was immediate and clearly audible, as expected. The reduction of the subtle hum from the amp’s toroidal transformer (mechanical noise from inside the chassis) was less significant than before, it takes probably more time to be effective as I’m used to hear.
Conclusions.
Hope that helps.
Up to you but the advice I got is that the gain on buying the deluxe Allocator when we already have the EMI and Grid Protectors is negligible . The synergy with. the 3 devices is quite remarkable. But beware Luca once you have the Allocator there is that little attachment on the Schnerzinger Power Cord for the Cable ProtectorYou also have the EMI Protector and Allocator as ingredients that are not in my cake, Steve. Can’t wait to add them too.
The Allocator is not a power conditioner How many have you seen that have antennasThe thing is how does the Allocator compare to other power conditioners.
I’ve given up trying to second guess what these are or are not Patrick. It’s the sense of engagement that i now have with my system which I have never had before For me that is all that mattersAgree...I also have never seen a power conditioner that claims to continue working after it is unplugged!
Please ask:and a few questions I suggest him to ask for me.
