Whats a DVM. I have a fluke true RMS meter. 600 volt. Not 1000.Do you have a DVM? I'd simply check the power supply Voltages and see if they are a concern. If the supply has significant Voltage (over 200V) then the 10K resistor needs to be able to handle some power- 5 Watts recommended.
If a connection is lost the amp is likely to simply not work. SETs are pretty simple and are likely to not run at all if a single connection is lost.
I have gold 10 watt resistors.
