3 Tonearms Kuzma 4point 9, 4point 11 and Schroder/Thrax CB 11"
All on a Kuzma Stabi R with an Lyra Etna(old non lambda)
Here are my observations...
The Kuzma 4p9 has been my daily driver for just under a year and it's been wonderful
Fast, airy, dynamic, great articulate bass and an amazing tracker but I have noticed that at times it can sound a bit lean...
The 4point 11 directly compared to the 4p9 is interesting....They are very similar as they should be
The 4p11 has much more weight to the mids and this to my ear is a big deal, the 11 also has a wider and deeper soundstage...
The 9" is however faster sounding but the 11" is no less dynamic....Maybe its the meatier sound that makes the 11" sound a tab bit slower....
But it is just as dynamic however...so that may be an illusion
The 4p11" with the Etna in MY system also sounds a bit darker and not as airy as the 9". And I have tried messing with VTA and so forth to no avail...
This coupled with the slowish character is something that keeps me from choosing one over the other....they both have great strengths and to me some disadvantages..
Enter the Schroder CB...
I've had this arm for a little while and tried it on a Garrard 401...I found it cumbersome to set up and on the Garrard it just never sounded right...
it was an utter disappointment..
after shelving it for awhile and having zero luck selling it I decided to give it another try...
On the Kuzma the Schroder CB is a different beast
Frank Schroder's recommends tensioning the different grub screws and bolts all to different varying degrees...
So after spending some time fine tuning the Schroder CB I finally got it to sound right...
it's dynamic and airy like the 9" Kuzma, not as much heft to the sound as the 11" Kuzma but more than the 9" kuzma....
Great bass...but the biggest thing to my ears is it's a more natural sounding arm...
Acoustic instruments sound so life like so real, an acoustic bass sounds like wood...
drums have air and you can feel the skins
Tons of texture and rich harmonics....
Just a wonderful arm....a very pleasant surprise
All 3 arms are world class...and just a little different from each other...
For the moment the Schroder CB strikes a great balance between the 2 other kuzma's...
