New Product Test: Ground Box Booster from Heartsound Audio
In addition to the fantastic, out of the signal path changes the Holostages made, I found the Ground Box Booster improves upon those, but also tightens everything up. Faster, more articulate bass from the REL, leading edge attack more pronounced, impossibly long decay is even longer, slightly more reverb resulting in an even better feel for the acoustics of the room in which the recording was made & overall more coherent presentation.
So overall you like the Ground Box Booster better than the active Synergistic ground block? How do the two directly compare in price/performance in your opinion?
That's a great question, but it's a difficult one for me to answer right now for several reasons.
For example, I have 10 Holostages scattered about (those little buggers are phenomenal), 1 Ground Box wired to the chassis screw of my Integrated & 1 Breaker Panel Box attached to the panel door. So, there's a lot going on.
The SR Active Ground Box is more versatile in that it can accommodate 20-30 ground wires. I forget the exact number. So, nearly everything that can be grounded is attached to it. That's a lot of expensive ground wires if you don't DIY.
In terms of performance, both ground boxes seem to lower the noise floor, enhance the bass, add body & clarity.
I believe SR & Heartsound Audio products are additive. For example, SR products seem to perform better the more SR products you have in your system. However, the HSA products may just interact with each other in a more audible way compared to the numerous SR devices I own.
That said, products from both companies seem to play well together. So, I believe your decision may come down to cost & scalability.
In fairness, I need to spend more time with the Holos, Ground Box Booster & Breaker Panel box before I can confidently render a final opinion. However, all early indications are the Heartsound products have made a more significant impact in terms of price/performance than the SR Active Ground Box.
But remember, I'm basing my opinion on the combined changes/ improvements to my system on the combination of several different Heartsound products working together versus one SR Active Ground Block, its power cord & ground wires.
One thing I can say with certainty is both companies offer a generous no questions asked trial period.
I'm planning to get the ground box when I get my next chunk of fun money. Also going to buy a few Sparko Op Amps and sniff some solder.
I found a great improvement using 2 ground wires (redundancy ) from A GBB. Not subtle. Give it a try. Different manufacturers and quite different lengths. Ab out triples the effect of the GBB.
Having some experience with her other products, I could totally see that happening just as you've said. Regardless it makes no sense whatsoever. But as Mark Twain said, "Truth is stranger than fiction, but it is because fiction is obliged to stick to possibilities; Truth isn't." I can't wait to try the GBB.
Reactions: Jeff4598
BREAK IN is real. 10 days.
No mention of a gnd box ...!
Exactly, I want to see the details of the product, specifications and various application. Ramblings/reviews on a forum from 3 or 4 people here are not cutting it. Also notice that I am only seeing these ramblings/reviews here, not on other forums. Lot's of work to be done before I shell out $1000.00 of my kids inheritance money (a pittance) on 4 black boxes. From what I am gathering some have an adhesive to stick to a breaker box, others have a ground jack to ground to your system.....
Sorry I am wrong found another forum that has a thread going and appears to be the same folks discussing it there also.
Has anyone used the Ground Box Booster with a Nordost QKore? Which model QKore? In what configuration (attached to the QKore, or stand alone from the QKore)?
Thanks.
I guess I posted listening results on the wrong thread about getting my Ground Box Booster. I have a lot of Heartsound products-- I think that this is the single most powerful item Krissy makes. I wired it straight into my Shunyata Denali ground with a solid silver wire / solid silver terminations. Highly recommended.
I got a lot of benefit from star grounding my whole rig so it may be that my system just had AC problems but now I'm getting that "late night" sound during the day. Best my stereo has ever sounded. Makes me want to skip work. Before my soundstage was in front of me with occasional sensation of sound behind me or off to the sides. Now I get so much sound behind me that I want to put some fake speakers in the back of the room just to mess with friends.
I also have to admit that I have been moving my Holostages around the room and changing their positions so that is probably part of the benefit I'm hearing. But I'm very excited and hoping to get a second one soon.
Reactions: PDXDrew
I have never used a grounding box of any sort. IMO, my system is pretty quiet to begin with. I have one of Krissy's GB. If you were to rank the order of importance on where to use them, what is the most important component? Mono Amps, Pre, Dac, Server, or Power Conditioner? Please provide your rationale to support your beliefs. Can you use one GB for multiple components? Thanks, I am trying to figure where to use mine.
My best results have come from attaching my Ground Box Booster doubled up on the preamp input of my Nordost QKore 6. I also tried it on the inputs of the DAC, QB8 distribution block, music server and amps. The impact when paired with the grounding post for the preamp was significantly better.
You can (and should) use one GB for multiple components. You should ground all* chassis grounds and all* signal grounds to it, with equally low impedance cables from each, star-grounded to your GB, and one big ground cable going to your isolated (or household) ground. You can just run all* grounds right to that single binding post. So components may have two or even three ground wires going to your GB. You may wish to get a solid copper ground bus bar to allow for more connections.
Doing this even without the GB will provide an improvement, so do take the time to star ground everything without the GB first (any ground bus or even a single spare binding post will work), that way you'll know what improvement is coming from the star grounding, and then when you add the GB you'll know what improvement is coming from the GB.
*Do not ground signal grounds that don't have continuity with the chassis, or otherwise are not supposed to be grounded! Here is a helpful worksheet from Shunyata that you can use with your multimeter: https://shunyata.com/wp-content/upl...ponent-Continuity-Test-Worksheet-Fillable.pdf
People who attempt star grounding report widely varying results. I believe this is because many do not use a multimeter to test their grounds and are probably improperly grounding things that should never be grounded in the first place.
Reactions: Willgolf
I've had a ground box for a few months now and wanted to give the Heartsound Ground Box Booster, it's due. Due too a bad lower back it took me a while to insert it into my system attached at the back of my long LSA Statement Exemplar modded integrated amp. Even though I've had wonderful experience with many of the Hearsound products I wasn't really expecting much. I installed it one night and listened the next day and heard my system get noticeably clearer and just plain overall better sounding. I plan to get a longer ground cable and attach to more components. I would say the improvement was up there with at least a full set of Holostages. I have, and still have, a lot of the ground control pigtails from Audio Prism and use on my amp, EVS heavily modded Oppo 205 SACD player, and speakers so figured I didn't really need a ground. I was wrong as it was a very noticeable upgrade to my system. It gave my system a more analog sound with no negatives whatsoever.
I was finally able to hook up my grounding box with pure silver wires from Japan, I have one wire going to my DAC and one to my Pre-Amp. I will wait until they settle in before making any comments.
