Is there a reliable set of parameters that allow measurement?
...Did I miss Loudspeaker's Spikes?
=> Does the type (genre) of Music we usually listened to,
has a direct influence on the way we think, talk, write, and make our decisions in life?
...Generally. ...With objection, or subjection, or without.
It's clear that something else changed between one measurement and the other. I'll guess you moved the measuring microphone. That's the only explanation for the null just below 70 Hz appearing in one graph but not the other. This difference is clearly due to room acoustics, not a difference between two electronic devices. Sorry to say, this means the entire comparison is invalid.
Off axis? It is my experience in my system that the sweet spot is expanded, that sitting on either end of a 9ft couch the image does not collapse.
Loudspeaker spikes and isolation pads are not necessarily useless.
I doubt it. I know classical music fans on both sides, and the same for all other genres. I do think that early (childhood) experiences set the tone for how accepting we are of belief-based evidence later in life.
--Ethan
That's precisely the level of "disappearing" we're talking about: the standing in front of the speaker "trick". And to emphasise, as I have numerous times, this is not easy! The slightest problem with the setup means that the illusion fails, and the reason is, that the gear then starts to produce sufficient distortion to give the ear/brain cues as to what's going on: that the sound is not hanging in space, so to speak, but is actually emerging from the drivers.That's a big sweet spot, Roger, but it's not what I'm talking about. I'm talking about getting up and walking toward one of the speakers. The size of the sweet spot varies, but when you get to the point where you're directly in front of one of them, you're going to know you're in front of it. In any case, I think we agree; given good imaging, speakers "disappear."
Tim
Tim
Ethan's technique of getting disappearing to happen is quite valid, the room positioning and absorption panels, etc, are minimising the impact of the auditory clues that the speakers are giving of where they are. It's another way of skinning the cat; personally, I prefer the fixing of the electronics approach, because it is more generally applicable.
Frank
Frank
Ok I have my system running for two hours. I can walk up to either speaker about 4ft away and I can hear the music behind the speaker. If I move closer the illusion does diminish. I sit about 13 1/2 ft from the speakers and the sound is what I call holographic as I can move off axis and the image does not collapse. I was playing RRCD-71 reference recording. If I stand in my kitchen about 35 feet back the image is still intact although a whole different perspective.
-----Good one! :b ...RR-71CD with [HDCD] encoded.
One thing I have observed is - the bass tends to be better in systems tuned by objectivists, and the systems tuned by the subjectivists tend to sound better in the midrange and top end.
As a result - most objectivists have linear but boring sounding systems. Subjectivists have engaging but flawed sounding systems.
I said that objectivists have forgotten how to listen.
This denial goes further - many objectivists at the fringes think all CD players, amps, and cables sound the same. And some even think that high bitrate MP3 is indistinguishable from CD. Nearly all claim that CD is superior to vinyl. I have heard valve amps described as "distortion generating effects devices".
If you start off by failing to acknowledge the important attributes that make a hifi system sound engaging, what hope do you have of producing a beautiful sounding system?
If I know objectivists and subjectivists, I can predict the response. Subjectivists will probably say "yes we should look more at measurements". Objectivists will respond with a big harumph and continue to deny there is any problem with their approach. Just my observation.
Yes, there are four parameter categories: Frequency response, distortion, noise, and time-based errors. Full explanation in my article from Skeptic magazine here:
Audiophoolery
There's even more detail about all of these issues in my upcoming book.
--Ethan
If you tested two deqx against each other and level matched, bet you could not hear the difference.
Tim, the engineer doesn't decide how the world works, or how the human physiology and brain interprets and compensates for the external stimuli, and the sensory apparatus workings. The good engineer recognises a phenomenon when it occurs, and attempts to exploit it. That is what I've done: I haven't run off to a textbook or read through a series of papers proclaiming that this "behaviour" is impossible, instead, I want to understand what's going on, and make use of it. The fact that 99% of others out there disregard it is irrelevant, my "schtick" is to get to the bottom of it ...I know that's what you're talking about, Frank. You've told us that you've put your ear right up to a tweeter and still been unable to locate the speaker. You've talked of speaker location and listening location having no effect on stereo imaging. You wondered earlier, why I gave you no credit as an engineer? These and other statements you've made make it difficult to believe you are an engineer. Sorry, but that's the bottom line.
Tim
So you are very close to what I describe, Roger. When my system is still warming up my experience would match that; the relatively low quality of my drivers means that they have to be hammered hard for a few hours to completely loosen up, and stabilise. Then, assuming no other interference effect, I get the full measure of disappearing: previous speakers in earlier setups with better drivers would disappear to the ear next to the tweeter level quite easily, but then I still had too many problems keeping the electronics from going off-colour -- so far it's always been a precarious balancing act ...Ok I have my system running for two hours. I can walk up to either speaker about 4ft away and I can hear the music behind the speaker. If I move closer the illusion does diminish. I sit about 13 1/2 ft from the speakers and the sound is what I call holographic as I can move off axis and the image does not collapse. I was playing RRCD-71 reference recording. If I stand in my kitchen about 35 feet back the image is still intact although a whole different perspective.
Tom, I agree that the "magic" happens in our head; so the trick is, to make it as easy as possible for our head to achieve that goal, of creating a convincing illusion. If we create too many obstacles, by introducing too much irritating distortion, our brains give up on jumping through the hoop to make the music seem real, so then, depending on "good" the reproduction is, either we start feeling fatigued, or the sound just seems to be coming from a hifi system. A very impressive hifi, perhaps, but still a hifi ...But Frank, perhaps 60% of two channel stereo is in your head, out of your control...you can not get to the b ottom of it.....as in, do you know what your thoughts are before you hear them in your mind? Our consciousness is really just a responder to what the "gate keeper" lets out from our unconciouss and all like that...
Tom
