It's a good thing my Lampizator and Playback Designs don't use chips.
And I believe (almost sure) neither does the Sonore exD and several others. I'm curious about the ifi iDSD too..but their literature
is hell to wade through.
And I believe neither does the Sonore exD and several others. I'm curious about the ifi iDSD too..but their literature
The JRiver link is correct, but you are taking it completely out of context. When it says, "By default, DSD will be converted to PCM for playback" it means that this is the default setting in JRiver. Those that have DSD DAC's don't need to use the default setting and can instead bitstream as it says further down in the wiki: "It is possible to bitstream DSD to certain DACs. This bypasses the DSD to PCM conversion."`
The "jriver" link was updated as recently as this year - right in the "history".
The iDSD units (Nano and Micro) use Burr Brown DACs chips. One in the Nano and two in the Micro.
Well if you can get the PS Audio, I'll let you borrow the Lampizator.....
Here is what they say:
"Having a chipset able to play all formats would count for little if this was not all executed natively; without conversion from one format to another. Using trickle-down technology from AMR (who drafted the chipset code) to drive this Burr-Brown chipset, the original music format remains unchanged which is essential to attaining the zenith in high-end audio reproduction."
True. iFi does make a point that they have separate conversion paths/approaches when handling DSD and PCM files in the Nano and Micro.
Well, is there an answer to the question above?
First, I didn't "quote" the jriver link - I *provided* it to readers, as they can take what they want from it.
And no out-of-context on John Atkinson. A slight misquote - but it's the same thing in the end.
What happened here is an audio reviewer was caught repeating something that *wasn't* true. Anyone that actually reads the technical-white papers on this subject would not assume that (certain) products are "bypassing" PCM conversion, in playback.
I brought thisup in a thread called "DSD-only DACs, a survey" over at Audio Asylum. The technical guru of AMR posted in response and supported the fact.
Read it.
First, I didn't quote the jriver link - I *provided* it to readers, as they can take what they want from it.
I brought this up in a thread called "DSD-only DACs, a survey" over at Audio Asylum. The technical guru of AMR posted in response and supported the fact.
Read it.
In case anyone is interested, Art Dudley's DirectStream review will be in the September issue of Stereophile.
Marc said, in response to me, that "it isn't true" that (almost all) SACD players transcode to PCM.
THEY ALMOST ALL DO.
