My wife has given me the go-ahead on the 1.7s. Will be adding these at the end of the month. Probably have the new KT120s in the amp by then as well.
Good value for money vis-a-vis performance. Their flagship 20.1 at $12,500 is just a mere fraction of today's top speaker designs under the $200,000 mark. I'm essentially 'glued' to my MG 2.7QRs for the last 12 years.
it seems that they are quite affordable and easily driven. one can start with MMGs and a sub and be quite happy like me. they do a lot of things right, they just take up a bit of room. theres plenty of models to upgrade to if one feels the little ones arent up to the job.
+1! A friend of mine drives the 20.1. They are truly great, and puts a huge question mark on current price development!
e
I for myself have found satisfaction with Merlin VSM and TSM's.
..if you are looking for the best, do so within yourself.
I have a pair of tympani 1D's that need the bass mid panels in both speakers replaced ( already replaced the tweeter panels some years back ) they have been packed up for many years and I am wondering if they are worth spending the money on to bring them up to scratch? If so what would be the best way to go about the panel replacement/rebuild, are the components still available from MAGNEPAN and the crossover components need replacing as well as they are shot and I was considering an outboard unit direct wired to each panel.
Any suggestions would be welcome as to the best course of action to take.
I can't wait to hear the 20.7's Frantz and as you say for no price change between the 20.1 and 20.7, how great is that
3) Place the subwoofer in front of the Maggies, and not behind. I once placed a 15" subwoofer behind each Maggie and found that the bass rattled the panels. Now, I use a single dual side-firing subwoofer with my 3.6's. Because of group delay, etc. In front also works better in my experience with most subwoofers. This is usually because the 3.6's have a 2nd order crossover, and most subwoofers have 4th order or higher in the low-pass crossover.
4) Experiment with height. I found that having a subwoofer off the ground worked best with my 3.6's - but it's not very practical unless the subwoofer does not vibrate much with self-cancelling horizontally opposed drivers (good example is the Martin Logan Depth).
