Best DAC/Preamp combo under $10k?
NewAudio
28
I am looking for an excellent DAC with integrated preamp max $10k (used preferred and <$10k used is OK for higher priced items - e.g. I would aspire to pay <$10k used for a $20k DAC/Preamp.).
If you feel I should best use separate DAC and pre-amp, then please do jump in - your input is most welcome!
Inputs are simply Apple lossless music ported directly to the DAC ( so an Apple connector would be a plus!, though I have a stand that directly passes through the digital content) and Toslink from Comcast and Plasma TV (TV has apps, Netflix etc). I may add a CD player (perhaps I don't need really high end if I port the digital output directly to the DAC?!) and a turntable at some stage.
I have Lamm ML1.1 monoblocks and a powered subwoofer (Funk) the analog output would feed into. So separate sub output would be great. As I have tube amps a tube DAC might be sensible, but I am not sure it matters - help me out here!?
A real volume control as well as a remote would be good. (some DAC/Preamps only have remote volume).
thanks very much, Brian
==> Some poorly researched thoughts from a quick Google and looking at what can be bought used.... Note a AV system might be OK but I would use it as a Preamp/DAC only.
• AMR DP-777 DAC/PreampMark Levinson No. 502
• Theta Digital Gen VIII Series 3 DAC preamp
• McIntosh d100
• Classe SSP 800
• Anthem D2V
• Meridian 861
• Mark Levinson 502 Media Center
• Mytek Stereo192-DSD DAC/Preamp
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
wisnon
3,536
640
1,200
Lampizator Level 5 or 7, Chord Hugo (no remote), PS Audio Direct Stream, VAD Dac, Calyx Femto Dac (not sure about preamp), Antelope Platinum dac, etc
NewAudio
28
Have you considered the MSB Analog DAC?
http://msbtech.com/products/analogDac.php?Page=../index
It seems to do everything you need, and it's more modern than most of the models you've listed. Oh, and it's under $10k...
alexandre
Yes - after I posted this I was doing some further searching and MSB looks like a top player. Now - of course there is the top model, the MSB Diamond DAC IV. Issue is if I buy the Analog - would I always wonder - gee what would it sound like with the Diamond? I do think the MSB DAC IV Signature Platinum can be had used closer to $10 grand though.
Question - comparison between the Diamond and Platinum and Analog does anyone have any experiences? My feeling is high-fidelity is like other technologies - one has to spend 10 times as much to get something twice as good, or at east better....
Brian
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Brian
Well, I own the MSB Diamond, but since your budget was $10k, I didn't even go there :)
As far as differences go, with MSB, you do get more once you pay more, but of course, whether it's worth it or not it's up to you.
alexandre
JackD201
1,429
1,820
Manila, Philippines
TechDAS D7i Supreme. Does DSD and PCM up to 24/192
SPDIF coax, Toslink, USB and a front Apple Port for iOS devices
Variable Output but no remote
No line level input so I wouldn't exactly call it a DAC/Preamp rather a DAC with an Analog volume control
US Price if the same as the Japanese price would be well below 10k at about $8,500.
Sounds good. It is smooth, detailed and has some balls. I've sold 3 already. I think I'll get one for myself along with a pelican case so I can bring it with me when I go home to the province.
That and my laptop and hard drives and I'm good to go.
Designed by TechDAS COO, Nishikawa-san's 15 year protege, engineer Kazuhiko Hashizumi. Another great, fun guy like his boss and mentor.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I would definitely try the new PS audio directstream ($6K). Not even shipping yet, but according to those what heard it a price/performance breakthrough - according to manufacturer (of course biased), it beat the $15K EMM Labs DAC2X in an A/B shootout . You probably get 30 day trial on a new unit.
Lots of innovation in DAC technology. You could probably pick up a used MSB Platinum in your price range (if a platinum ever shows up - you can get a used signature for around $15K), but there is no guarantee it will sound any better than the directstream. Only listening can tell. In fact, I will audition one myself once I can get my hands on it and do a double blind shootout against my MSB Signature.
cat6man
913
1,050
1,185
west of NYC, east of SF
Brian
I was interested in the Analog and went to a dealer to listen. It sounded fine but was way below the signature MSB that was also at the store...........the Diamond is only better. Since the Analog can't be upgraded, you might want to consider a used Platinum or Signature for a little more than $10k. It would be a pretty good step up from the Analog.
I also wanted to stay under $10k and went with the TotalDAC D1-dual but no analog input as with the MSB.
4,704
As you will probably be able to listen to one before me I hope will post your findings as soon as you get it. People can call it good marketing or audiophile hype, but I am really curious about this unit. Unfortunately it seems the launch in Europe will be not be simultaneous with the presentation in the US.
Alrainbow
3,260
1,431
450
I have ordered one as well. And I will do a comparison with my msb. How ever even if the msb beats it in some ways
That still makes it a good choice with adding in the price. I also have a lampi 7 being ordered I do not expect it to be better but different. As I want to hear what edorr says as much as mine. The reasoning is simple at this level a very critical ear is needed . And I do trust mine but do want edorr,s as well. I use my current Pwd with an offramp 5. And it makes the Pwd mkii a far better dac than without . So given ps audio has found a way to allow the dac to shine with USB as they claim
I would think it is a good contender. However catman is looking for a analog input too.
Al
wisnon
3,536
640
1,200
Al
Buckle up for the L7 AL, its in another league to the L5...which is already great.
Alrainbow
3,260
1,431
450
I am sure it is. And how lucky am I to know someone to help guide me in the purchase. This will be pretty cool to have the dac,s I have and be able to compare. And thanks for all your help Norman , I was lucky to find you.
Al
wisnon
3,536
640
1,200
I was lucky to find you too. I have made several good pals in this hobby that I may never have met otherwise!
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I put in the order and I was just notified I missed out on the first batch, so I probably won't have it before end of May....
