I have a question as a non-techie. I have read that both the amp and the speaker load have various different impedance levels across each cone, frequency spectrum...and since music changes all the time...the actual load impedance changes constantly on both sides of the cable.
The network cables are supposedly adjusting for that (at least in the case of Transparent which adjusts each network box for that equipment)...
...does the square wave test challenge the speaker cable to produce a square wave thru such a varied input and output impedance level across various different loads?
I am not trying to be controversial...only to learn. I have read that many tests don't necessarily address all the many issues that audio presents in trying to create great products. Then again, this may not be one of those situations...thanks for any clarification.
Electronic equipment have fairly stable output impedances and very stable input impedances. (Input impedance is usually a simple resistor.) Speakers, on the other hand, can have a wildly varying input impedance, based on frequency. These varying impedances are far too complex to account for in a speaker cable.
A square wave tests signal integrity in both the frequency and time domain, and only up to the test frequency. Ie. a 12k Hz square wave will require all frequencies up to and including 12k Hz to be both equal in magnitude and arrive at the same time. Complex loads (such as networked cables and speaker crossovers/drivers) will alter one of both of these properties.
BTW, while no one sits and listens to square waves. (They are remarkable annoying) Their usefulness is still very high, especially to those who understand the full ramifications of what their results say.
BTW, good sounding cables editorialize.
In the ear of the boholder!
I recognize that a vast majority of audiophiles like and prefer editorializing. I, for one, do not. I prioritize fidelity.
Although none of us knows exactly how Transparent Audio designs their cables,
Not entirely true. There are those that have carefully cracked open those boxes and done a little forensic style reverse engineering. It's difficult and time consuming. But curiosity can be a very motivating force.
I think Micro goes on to say that their primary 'refining tool' is mainly the impedance values.
It's their only refining tool.
I do find it interesting that both Wilson and Rockport use Transparent cables inside all of their speakers. (I presume there are no network boxes inside...just the wire.) And its been this way for years/decades if I am not mistaken. My X1s are wired with Transparent inside.
Do people think this is co-marketing...or is there something to their wires (let alone the network boxes) that such respected designers would use them for so many years?
Additionally, Rockport uses TA cables in their own systems as you can see clearly from all the reviewer visits to Rockport, as well as Rockports own pictures. Wilson frequently shows their stuff with Transparent (though perhaps with other cables as well?)
Just curious if anyone has ever spoken with either manufacturer about this...
Yes. It is very much a mutually beneficial business model. TA uses Wilson speakers and Wilson uses TA. It has been a collaboration so long standing, why rock the boat now? Vandersteen and Audioquest are similar. Richard Vandersteen and Bill Low are long time friends. This sort of thing goes on all the time.
P.S. TA cables minus the networks is nothing remarkable. I'm not saying it's crap. It's just not any sort of technical marvel. And by the way, the only cables that Wilson used by TA in their speakers are the ones that unite the various units. Ie. the cables that were exposed while connecting the bass to the head unit. Internally, Wilson used (at least last time I checked) nothing more special than Monster Cable. (if that)
Back to cables...if the amp and speaker in a test were actually a simple signal sent by a piece of test equipment to a 'receiving test equipment' (rather than speaker)...would that be different than the actual situation where the 'speaker/receiver' is requiring the spectrum of sound to be sent slightly differently across the spectrum than a piece of test equipment (ie, to get the bass, need more juice, need less juice in mids, and then super-low impedance above 17khz, etc)?
does a cable therefore need to be adjusted to 'ideally' deliver the signal across based on the 'particularities' of the amp and speaker?
The full complexity of a speaker load cannot be accounted for by a speaker cable. Many speakers can and do vary wildly in their impedance. This is usually contained in their bass regions where most of the electrical resonances takes place. But to try to fully account for this varied impedance would require a cable network that is more complex than the crossover thats inside the speaker. This is not what TA is doing, nor is it necessarily possible.
The basics of TA are that their cables are designed to roll off the frequencies above the audible range. In order to do this, the single most important factor for them to know is the output impedance of whatever equipment they are connecting to. And just like speaker crossover complexity, the steeper you want that roll-off to be, the more complex the network must be.
I would never buy TA myself, but I have a long time friend who has a ton of the Ref. XL. Three different source components. One Pre, but two different amplifiers. (one tube, one solid state) And two different speakers. (at any given time) He's not exactly technically minded, so when going about ordering all of these cables he asked me to help him out. This is when I came to realize that it's the output impedance that counts the most. Having all of these cables at my disposal has also allowed me to try out various combinations. Ie. Three different source/output impedances and one control input impedance in one instance. And one control output impedance and two different input impedances. And thats just the interconnects. Its a virtual TA playground! haha.
