I said I would never buy another Turntable...Argh !!!
rockitman
7,097
414
1,210
Northern NY
I'm beginning to think the traditional, offset castors make sense for the turntable stand. It appears that my 3" square box leg specification makes the stand quite heavy. In my case, that means, to make all three stands (two stands with a top to accomodate a TS-140 and one stand with a top to accomodate a TS-300) the same, I would get castors on all three stands.
stand placement logistics is an art managing where components and TT's reside in/on racks and having the right length's for interconnect to reach said components without having to pay the wire whores their exorbitant prices for the "best" cabling in longer lengths than you already have.... :wink: :cool::p:b
4,702
Yes...the raw steel must be blanched if you go for clear coat vs an opaque color. I can't answer the color question of the raw steel pre-blanch.
I will find out more about the caster wheel/footer they are supplying for the table.
Why putting caster wheels on the table? Since you already own the excellent Wilson Audio jack, get two narrow wheeled platforms just 1/2' higher than the lower part - when wanting to move lift slightly with jacket from side and place the platforms under each side of the whole system. When in place lift a bit with the jack and remove the wheeled platform.
Mike Lavigne
Apr 25, 2010
12,602
11,694
4,410
looks like while I've been playing 'audio-nerd' at RMAF you guys have been working diligently to iron out the details on these racks.
thank you.
I did do some work; spent an hour and a half at an excellent tone arm tutorial by Frank Schroeder. very enlightening.....if mind challenging for a non techie like me.
16,220
13,684
2,665
Christian, what type of steel do you have for the top on your current custom Herzan stand?
harleyguy
134
18
248
HELP ME american sound was made by don't know.how can some one else start making them and use the same name.help me understand this
Tango
4,938
6,269
950
Bangkok
I think the personwho makes them now doesnt care what the new owners call it.
Kind regards,
Tang
16,220
13,684
2,665
Thank you, Christian!
Sweating every detail of the custom stand for hours I enjoy doing. Auditioning AC outlet cover plates -- not so much. :)
Tango
4,938
6,269
950
Bangkok
Desk, computer workstation removed. This will be the general area the AS will be located....might need to add a third phonostage....;)
Additional phono, longer phono cable, more interconnects, more power cords, custom Herzan active anti-vibe table, two more sets of arm/cart. This project is approaching the price of your F12, Christian :p. I bet you didnt realize it would go so big at time of decision to buy the hammer...hahahah.
Tang
PeterA
12,669
10,942
3,515
USA
Tang
Christian, What kind of power cord do you plan to use on the Herzan.
Just kidding.
Mike Lavigne
Apr 25, 2010
12,602
11,694
4,410
Tang
when you figure Christian will likely subtract one tt from his current line-up (freeing up at least 2 arms, carts, and 2 phono inputs) once he grasps the full realization of what the AS brings to the table, then all those other 'accessories' will fall into line.
if he fully supplies the AS prior to that compare, then.....yes.....that could get into the crazy realm.
for me right now for the AS, i'm just thinking 2 arms like I have, and then grow into the other 2 organically. I have the cartridges now for 4.
bonzo75
22,650
13,685
2,710
London
Which are the other carts?
rockitman
7,097
414
1,210
Northern NY
Tang
LOL Tang....The only thing that doesn't bring a smile to my face is dealing with wire cartels....
16,220
13,684
2,665
rockitman
7,097
414
1,210
Northern NY
Here is the footer/caster for the NDW-23. It is pretty much the only recommended footer for the table. Wheel into position w/o equipment on top, dial the footer down to get wheel "off load" and level the table. It comes in any color you like as long as it is this off white. They won't be very noticeable under the big legs of the table.
I changed my mind to powder coat black to match my other racks. The white avi modules and controller in white won't bother me...almost like a silver component I have now on black racks.
16,220
13,684
2,665
Yes, thank you, Christian!
Kingsrule
1,444
704
1,430
It's 1/2" Hi Strength Aluminum. Standard top they use.
Did u consider a top made from Panzerholz? I have the same Al shelves on my Herzan racks and I'm thinking Panzerholz would be ideal....
Trying to find Panzerholz to buy is a whole other issue.....
rockitman
7,097
414
1,210
Northern NY
I did and quickly ruled it out based on David's recommendation...too dead sounding for the table support. Steel plate is best for this heavy stainless steel beast.
