Tripoint troy signature grounding device
The supply of Dalby's products is unstable too, so Chris is rather quiet on Dalby ground cables too.
Most Troy Signature owners in HK if having 2 or more of them, will use one for digital and one for analog components.
Of course diff systems will behave differently.
I use two posts of three for pre amp and phono, the third one for digitals. I dont hear any deteroriation in my analog from possible digital contamination. I have another Troy for a pair of monos that are five meters away. Ran out of grounding cables, I still havent ground my subwoofer amps.
The Dalby ground wire I saw was bigger than my wrist.
Can you maybe remember the retail prices of these Dalby grounding cables?
And Tripoint emperor grounding cable still reigns supreme, also in HK, as far as I know.
Sawasdee Audiocrack,
2 meters of Dalby flagship retails around £13,000.
You mentioned you are using a few Thor's. Do you use them with your amps and pre amp. Are your amps and pre amps solid stage or tube? And would you say using a few Thor's, tend to clean up sound and possibly make some system sounds a bit cold or lean. Apologize for these knit pick questions. I am deciding which way to go Thor or Dalby for my system. AE seems to recommend Dalby which is rich in tone and coherent as they described.
Best regards,
Tang
Best regards,
Tang
Hello Tang,
I have my Thor grounding cables connected to my two Kondo tube m1000 preamps, my Trinity combo and Lampizator Golden gate dac. I did not connect them to my Kondo pp and se Gakuoh poweramps because the Thor's are very heavy cables, the Gakuoh misses a dedicated grounding binding post and the screws of the Gakuoh are tiny.
I do not have any experience with the Dalby cables so do not know how good they are and how they compare to the Tripoint Thor grounding cables. What I do know is that the latter sound fantastic.
The Thor does not introduce any coldness or leanness in both my systems: on the contrary, while introducing better transparency and better dynamics due to the lower noisefloor all instruments are starting to sound more 'real', that is you get the feeling that the electronic equipment vanishes and the sound becomes more pure, liquid and smooth in a way that resembles instruments being played in front of you.
Does this answer your questions?
Hello Tang,
Thank you so much Audiocrack. Information from you has been very valuable to me. I guess anyone who have tasted that "more real" sound would just want more of it.
Tang
Tang
Please keep us posted, Tang, on your experiences with various grounding cables if you are going to try out different brands.
My experiences with the Thor SE are exactly the same. Can imagine what the Emperor would bring to the table...
Tang, I entirely support what Audiocrack has said. I have four Thor SEs and have found that I really need a fifth one. I have one on my amp, one on the preamp, one on the phono stage, and one on my music server and dac. I need another for directly on the dac. The dac is new and initially I used one of the original silver grounding cables to the dac. I had several people up from Houston and one wondered whether I could do any simple A/B comparison. I took the Silver off the dac and was about to return to my seat when she said 'please put it back!' I totally agree with what she said.
Later I thought that I could take the Thor SE off the phono stage and attach it to the dac. Wow, that improvement just left me in awe and resulted in my ordering another SE. I have since reattached the phono stage with it SE after listening to it with the Silver.
Each and every Thor SE has added more realism to the sound stage and definition to placement on the sound stage. One can hear the decay of notes, human noises, and the total character of the instruments. I find it quite difficult to read or do anything but listen to my music.
I should note that the Dalby ground cable is merely multi-strand wire, while the Thor SE has heavy shielding.
Sawasdee TBG,
I am very curious of this Dalby top cable. Only one way to find out right?
Tang
for my Tripoint Troy Signature, I do have 1 Thor Master Reference ground wire that I connect to my preamp. then 4 other standard Tripoint ground wires I use for (1) dac, (2) SGM server, (3) power supply of my tt, (4) the stainless steel arm board for my tone arm.
the Thor is a big jump over the others in performance. but it is $6k USD retail.
who you want to ask about this is member 'Audiocrack'. he has multiple Tripoint boxes (including the un-obtainium Emperor) plus multiple Thor and higher ground cables. I'm small time compared to him.
Mike, I now have four Thor SEs and a fifth on the way. I have repeatedly demonstrated how superior the Thor SE is over the Silver and this resulted always in my buying more Thor SEs. But the top grounding cable is beyond what I'm will to buy and thus I won't listen to one.
I listened to the Dalby Celestial connecting from Pre to Troy for a few days already. This is replacing the normal silver ground wire. Obviously much better than the normal wire but I dont have and never tried the Thor so I dont have a reference point. The Dalby is bringing the realism of my system yet to another level. These grounding things are really addictive. I am goin to buy more grounding cables for my phono and amps.
Best regards,
Tang
Best regards,
Tang
Best regards,
Tang
Congratulation!
You bought it via the local dealer or from Chris of Audioexotics Hong Kong? ;)
Congratulation!
I have my agent bought from Chris AE.
Kind regards,
Tang
Best regards,
Tang
Glad tou like the Dalby grounding cables Tang. Don't you think it would be wise to try one of the better Tripoint grounding cables as well in order to find out which grounding cable you ultimately prefer?
The q is more why at these price levels Tango wouldn't a/b Dalby v Troy SE
Esp w AE stocking both brands
Ha! Rudolph beaten me to the punch
As someone considering Dalby cables I'd like to second that; would dearly love to hear the results of such a comparison
I heard through the grapevine that the Dalby cables sound more 'romantic' than the Tripoint grounding cables. Have not heard any Dalby grounding cable myself though so I cannot comment based on my own experiences.
