Most Troy Signature owners in HK if having 2 or more of them, will use one for digital and one for analog components.
Of course diff systems will behave differently.
Can you maybe remember the retail prices of these Dalby grounding cables?
And Tripoint emperor grounding cable still reigns supreme, also in HK, as far as I know.
Sawasdee Audiocrack,
2 meters of Dalby flagship retails around £13,000.
You mentioned you are using a few Thor's. Do you use them with your amps and pre amp. Are your amps and pre amps solid stage or tube? And would you say using a few Thor's, tend to clean up sound and possibly make some system sounds a bit cold or lean. Apologize for these knit pick questions. I am deciding which way to go Thor or Dalby for my system. AE seems to recommend Dalby which is rich in tone and coherent as they described.
Best regards,
Tang
Hello Tang,
I have my Thor grounding cables connected to my two Kondo tube m1000 preamps, my Trinity combo and Lampizator Golden gate dac. I did not connect them to my Kondo pp and se Gakuoh poweramps because the Thor's are very heavy cables, the Gakuoh misses a dedicated grounding binding post and the screws of the Gakuoh are tiny.
I do not have any experience with the Dalby cables so do not know how good they are and how they compare to the Tripoint Thor grounding cables. What I do know is that the latter sound fantastic.
The Thor does not introduce any coldness or leanness in both my systems: on the contrary, while introducing better transparency and better dynamics due to the lower noisefloor all instruments are starting to sound more 'real', that is you get the feeling that the electronic equipment vanishes and the sound becomes more pure, liquid and smooth in a way that resembles instruments being played in front of you.
Does this answer your questions?
Thank you so much Audiocrack. Information from you has been very valuable to me. I guess anyone who have tasted that "more real" sound would just want more of it.
Tang
I should note that the Dalby ground cable is merely multi-strand wire, while the Thor SE has heavy shielding.
for my Tripoint Troy Signature, I do have 1 Thor Master Reference ground wire that I connect to my preamp. then 4 other standard Tripoint ground wires I use for (1) dac, (2) SGM server, (3) power supply of my tt, (4) the stainless steel arm board for my tone arm.
the Thor is a big jump over the others in performance. but it is $6k USD retail.
who you want to ask about this is member 'Audiocrack'. he has multiple Tripoint boxes (including the un-obtainium Emperor) plus multiple Thor and higher ground cables. I'm small time compared to him.
I listened to the Dalby Celestial connecting from Pre to Troy for a few days already. This is replacing the normal silver ground wire. Obviously much better than the normal wire but I dont have and never tried the Thor so I dont have a reference point. The Dalby is bringing the realism of my system yet to another level. These grounding things are really addictive. I am goin to buy more grounding cables for my phono and amps.
Best regards,
Tang
I have my agent bought from Chris AE.Congratulation!
You bought it via the local dealer or from Chris of Audioexotics Hong Kong?
Best regards,
Tang
Ha! Rudolph beaten me to the punch ??
Glad tou like the Dalby grounding cables Tang. Don't you think it would be wise to try one of the better Tripoint grounding cables as well in order to find out which grounding cable you ultimately prefer?
As someone considering Dalby cables I'd like to second that; would dearly love to hear the results of such a comparison
