Very cool, this makes for at least four huge super systems... the big Lansches, Von Shweikerts, YG Sonjas and now the big Wilsons. Am I missing anyone?
I read that GR-Research is going to have a large speaker/sub system their room:
Nine custom modified BG tweeters per channel
Twelve custom made high Q woofers per channel
H-Frame dipole active subwoofer panels with integrated plate amplifiers
3 12? servo subwoofers per channel
Non-square open baffle design for reduced cabinet resonance and reflections
Open baffle for much less weight in such a large speaker
Open baffle allows for easy access to passive crossover network, allows for easy customization and lessens the impact of microphonics on the crossover components.
92 db/1 watt at 1 meter efficiency
87 db/1 watt at 4 meters due to the nature of a line source array
7? tall array for true line source performance, even in very large rooms
8 ohms nominal impedance
Passive subwoofer crossover between preamp and power amp for less stress on your main amplifiers
Custom veneers available, from tasteful, to the extreme
18 tweeters, 24 woofers, 6 subwoofers
Greater than 2,000 watts power handling for the tweeters (more for the mid/bass drivers)
Cabinets built in the United States
Speakers assembled in the United States
