Who can build me a custom stand?
ack
May 6, 2010
6,774
1,208
580
Boston, MA
I am looking for a custom polished chrome stand - can you suggest places that would be able to help?
thanks
Any metal stand can be chrome plated. Buy one or build one then have it triple plated; copper, nickel, chrome.
Thanks. I should clarify this is a custom LP stand, with custom dimensions as well. I have contacted all of the above...
Hi ack,
We recommend Harmonic Resolution Systems stands. There SXR versions can be configured just about any way you want. They can be reconfigured if needed in the future. Each isolation shelf is calibrated for the weight of the component that will go on it. If you change a component in the future the shelf can be re-calibrated. We feel it's the best stand available. I don't think they do chrome however. The same isolation bases are used for amplifiers, and again calibrated to the weight of the component. A "final purchase". It will last a lifetime. *****
BR,
Terry
Glass looks good, but is really one of the worst materials you can use for isolation.
TM
Oh what the heck. I'm a distributor and I use these myself. :D
Critical Mass Systems
Soundanchors
So I should have clarified when I started the thread long ago... I wanted a custom stand for my LPs (EDIT: oops, I did, in post #6)... I am going outside the audio domain and building a custom wall unit from Roche Bobois... Thanks for all the suggestions.
Never mind! :)
I recall someone saying IKEA had such a unit for sale.
I always wondered about metal vs. wood (maple).
