All of the above and CD too.
Myles, you are right; CDs are also made of vinyl (a substrate of), I believe.
But the contact between the laser and the CD's surface is not physical, but through laser light.
And because of that and as opposed to LPs, there is a need to replace your cartridge, and also your album, after a certain time. The sound will deteriorate because of a wore needle,
and the grooves of an album will also wear off after so many plays.
CD players don't fare much better; the laser mechanisms and the motors also wear off with time.
Synchronisation, fine speed & laser adjustments, jitter, motor noise, disc clamps, etc., are all contributing to a less or more accurate sound reproduction.
The CDs themselves can develop 'rotting' with time; but precautions can be taken.
And as with LPS there are cleaning products.
Turntables to play records are much more finicky to setup overall than CD players though.
You know that first hand yourself, and you have to get up of your chair every twenty minutes or so. But the effort is worthy of the reward (sound) or you simply wouldn't bother.
Plus the special essence of a record spinning on a turntable is unique in relaxation.
...With all the 'processions' and methodic cares; read addictive rotations or some' like that.
R2Rs are also prone to similar conditions; mechanically and conditionally (tapes) wise.
Now here's a question for you:
What is the average speed of a spinning CD when on playback audio mode?
...The number of rotations per minute. ...Near half way (diameter).
__________________
* Listening to
Classical Music right now, on the r.a.d.i.o. :b
