UDMA Enabled Flash Cards
How many of you are using UDMA CF cards and if so what if any differences are there in picture quality?
"The advantages of UDMA over previous transfer modes are the use of double edge clocking. That means data is transferred on both the rising and falling edge of the clock. This not only doubles the data transfer rate per clock, but also results in increased reliability by the use of cyclical redundancy checking (CRC) for data transferred over the bus."
I understand that data is transferred more quickly. How do these UDMA enabled cards differ from cards that transfer 15X-60X
My last question is whether UDMA Enabled is only available for Compact Flash cards or are they also available for SDHC cards? I ask this latter question as I just bought a Canon S95 to take on a cruise next month and am wanting a top notch SDHC card
DonH50
Jun 22, 2010
3,961
321
1,670
Monument, CO
There should be zero difference in picture quality (in this case, bits really are just bits), and having CRC is a big advantage. A clock signals goes up, then down, up, down... Standard transfers happen once per clock cycle, using just one edge of the clock. UDMA (and DDR memory) use both edges, transferring twice as much data per clock cycle (period). This requires greater bandwidth circuits as capture happen twic as fast (in half the time). Error correction (CRC) helps maintain data integrity despite the higher rates.
I don't have any (getting a good DSLR got put off for a while) but have friends who like them a lot. Don't know about SDHC versions, but they should work fine. Get good ones, not generic (I have had, and heard, of many problems with the copies) from B&H or whomever.
I wil say that I am not sure there's any real benefit with an S95 except when you download the pix to your PC. The faster cards mainly benefit cameras with lots of pixels and high burst rates.
That was my thought as well Don
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
I wouldn't worry about the lingo that manufacturers use to describe how they get higher performance. UDMA was a technique uses a while back so it is no longer an innovation.
What matters is the exact throughput you get in your camera and in your PC. These are different things as cameras are usually a generation or two behind the card capability.
Fortunately, there is a great resource to get this data: http://www.robgalbraith.com/bins/multi_page.asp?cid=6007
Rob benchmarks many cameras and cards against each other and posts the data int he above database. It is focused on DSLR cameras though as those are the people who usually care and need the speed. A P&S camera doesn't usually have the frame rate to require the highest performance. Still, if you buy a card which has high performance with DSLRs, then it is likely to be a fast card regardless of where you plug it in.
He also benchmarks flash card readers.
Only hitch is that he has been slower to update his database than when he started.
DonH50
Jun 22, 2010
3,961
321
1,670
Monument, CO
OT: Amir -- Can USB actually do DMA? Is that just in the camera? I am not sure the USB protocol and if the drivers have DMA (I am asking because I do not know, something I have not looked up).
Curious - Don
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
I have not had to write a driver for USB so don't have first hand experience. That said, whether a device supports DMA is a function of the host interface and in the last 10+ years, it has become trivial to provide DMA support in these controllers.
