Subs are tricky. I've recently given up on trying to integrate subs into my system. For a few months, I had been working on a way to do it that I might be satisfied with, but it won't workout.
In the past, I've noticed that a sub can make a bass kick more impactful. The problem I've run into though is getting that extra bass out of the floor toms and the other higher toms as well. Basically, the toms can sound overdone and unrealistic to me. Mostly, this stuff depends more on the room and setup. I certainly think your speakers can get it done without subs. I just don't know if that's possible in every room. In my room, bass is very flat and articulate. The sidewalls are treated to deal with a very high Q SBIR. I have 6 modex plates in here so bass is pretty great. I may add more modex plates to the side walls. Ive found that you can add just as much dynamic range including bass with smart bass trapping.
Question: as a guy who used to a lot of tech directing on theater productions, I remember bass and drums a lot during rehearsals. As a drummer, do you find that well set up subs produce kick drums well? With my X1s I find the bass kick to the chest is only done well with my sub and I absolutely love it and always miss it when I hear sota systems at dealers whose full range speakers without subs just don't hit me in the chest with that quick blow of almost compression which you get even when the drummer is playing but not trying to kill it.
