I prefer the Funk Achromat, but the Zavfino leather mat is very good on top of a rubber mat, which otherwise on its own often results in a rather 'rubbery' sound character.@Solypsa - the AudioSilente is high quality. However, compared to the Micro mat, it is significantly thicker. I like the Micro mat but mine is the doughnut shape that is used with its own vacuum platter. I think I hear the thickness effects so I am looking for something thinner to try. Micro's own leather mat for regular platter is too expensive to try.
@Shuggie - looking like it, thanks for the suggestion! Do you use it yourself? How do you like it?
Can you please explain a "rubbery" sound versus a "non rubbery" sound.I prefer the Funk Achromat, but the Zavfino leather mat is very good on top of a rubber mat, which otherwise on its own often results in a rather 'rubbery' sound character.
Simple - rubber mats seem to me to impart a heavily damped sound character that robs 'life' and 'vibrancy' from the music. Rubber mats are great for folks who obsess about their platters 'ringing' and never listen to any alternatives, but otherwise they are a cheap to produce option that's not often the best for sound quality. I will make an exception to this broad statement - the original Thorens TD-124 hard, ribbed rubber mat is by far the best sounding option on those decks, but it's hard rubber, so not quite the same thing as most soft rubber mats.Can you please explain a "rubbery" sound versus a "non rubbery" sound.
they´re Hiraga clones made from hard baby pig skin....I have 3 here, but haven´t tried them yetYou can contact Stefano Bertoncello @ Twogoodears - I think he does thin leather mats.
Do you have his email? I tried to send him one through his blog and it got kicked back.You can contact Stefano Bertoncello @ Twogoodears - I think he does thin leather mats.
I don't agree. The platter pad's job is to control resonance in the LP caused by the stylus tracking the grooves. If the mat is too soft, the vinyl depresses and might sound rolled off. If its too hard, might be too bright. The pad should be the same durometer as the LP in order to absorb vibration and prevent coloration. It helps if the pad reduces resonance in the platter too.Simple - rubber mats seem to me to impart a heavily damped sound character that robs 'life' and 'vibrancy' from the music. Rubber mats are great for folks who obsess about their platters 'ringing' and never listen to any alternatives, but otherwise they are a cheap to produce option that's not often the best for sound quality.
So a blank record?... The pad should be the same durometer as the LP in order to absorb vibration and prevent coloration.
Almost! A solid bit of vinyl, perhaps with an aluminum disk embedded (to help the pad keep its shape), would work quite well.So a blank record?
Spare one for crispy roasting. Taste great dipping with sweet soy sauce. Eat together with chinese bun.they´re Hiraga clones made from hard baby pig skin....I have 3 here, but haven´t tried them yet
