Yes, Goebel makes an excellent ethernet cable too.Well the other Göbel cables are just as good
Hello Mike,
Will you borrow one and test it on your home network?
Hello Mike,
so would adding a better Ethernet cable (or better Gigaswitch or LPS) beyond the fibre have any role in the 'streaming' performance or the local files on my server?
i don't know the answer. likely Emile does.
Hello Mike,well....er.....soobut my NAS won't be a factor in the performance any longer.
Hello Mike,
Though reduced in magnitude of impact, yes, all audible.
Hello Mike,
If a good usb cable on the optical ProUSB still gives sonic improvement, so will a good ethernet cable on your optical ethernet.
BTW please do an experiment after you have installed the PCIe memory in your Extreme.
If the NAS is still active and connected to your switch, upgrading the NAS ethernet cable WILL still affect sonic performance even when you playback only the internally stored musical files inside the Extreme.
The effect is not large but still clearly audible, particularly via your hi-end system.
Looks like the sotm switch has two fiber in/out connectors. Are these compatible with the Extreme spf?.Do you believe that this would be a better option then AQVOX SE?, A question to Emile about the new intona isolator 3: I am using the sotm txultra. Is the intona a better choice? The sotm has no galvanic isolation but better quality clock
Best, Carlos
Thank You EmileThey’re open SFP slots. Same as on the Extreme. So you have to use 2 fiber SFP modules, those have to be the same. SFP is a generic connector standard. There are copper cables with SFP connectors aswell.
The sotm tx ultra is a downgrade for the Extremes USB performance.
Some interesting snippets of information above. Take the above quote. Theoretically it doesn’t make sense for an upstream cable with no feed into the final locally stored stream to affect SQ but according to CKK it does. This is also my experience with my Innuos Statement. Is it because the upgraded cable allows less EMI into the system? I’ve upgraded several upstream remote stream cables and each time heard a useful uptick in performance from locally streamed files.Hello Mike,
Some interesting snippets of information above. Take the above quote. Theoretically it doesn’t make sense for an upstream cable with no feed into the final locally stored stream to affect SQ but according to CKK it does. This is also my experience with my Innuos Statement. Is it because the upgraded cable allows less EMI into the system? I’ve upgraded several upstream remote stream cables and each time heard a useful uptick in performance from locally streamed files. (...)
I also use SOTM Switching Herb.
This product's strong points are various.
1. OCXO clock makes sound signals more exact.
2. This herb can be installed by two SFP GBICs.
So If Sotm is used, Startech FMC connection is more perfect I think.
Actually I used HP-1810 Korean custom herb, SOTM herb is more better than HP-1810.
And SFP modules can be also used.
As my thought, SOTM herb is the best cost-effective product now.
IMHO it is the big issue with current digital streaming or servers. When we say that "Theoretically it doesn’t make sense" it is just a nice way of saying that we are not really understanding at all what is happening , but we got some nice sound differences when we tried it.
In all fairness I expect that when I get a top server - something I will expect to consider next Autumn - I will not be dependent on tweaks on the internet line other than a fiber optic link. Or at less that I will have a reasonable explanation for them.
What is the sotm switch herb? Are you reffering to the snh-10G?
If you put this switch between your router and streamer with fiber connection from switch and sfp tranceiver on the streamer( being without fiber connection) does it make sense?
Sotm herb= sotm snh-10g?Router - RJ45 Cable - 1st HP 2530 - Fiber Cable - 2nd HP 2530 - Fiber Cable - SOTM Herb
- Fiber Cable - SGM Extreme or SGM 2015 EVO
Now I use this connection.
When I receive Startech FMC, my ethernet connection will be changed
If your streamer doesnt accept fiber, is there any way to insert sfp module on the ethernet input of the streamer?Sotm herb= sotm snh-10g?
