The Mephisto is darker sounding and doesn’t do much wrong but its weight is back breaking and the heat it produces is something else.Whoaa!!!! Many, MANY congratulations! How do the Mephistos compare with the Trinity amps? I owned the Mephisto for a number of years (and before that the Colosseum...and before that the Antileon original). So know it pretty well.
Hi, were your VK500’s monoblocks as I see one for sale that is a stereo amp, albeit a dual mono amp with two IEC outlets. Thanks.Here’s a suggestion from left field! Years ago I owned a beautiful pair of Extremas and powered them with BAT Vk500 monoblocks. Sounded wonderful. You may still be able to pick up a pair of the VK500s but if not already done, they’d certainly need a thorough service and all their capacitors replaced. If I were setting up a pair of Extremas today, the first amp i would audition would be Devialet….either the 440 monos or the 1000 monos. Its French and like a lot of designs from that country, uses an unusual topology. Firstly its a ‘one box’ unit with DAC, Preamp and amp. It has by far the lowest distortion spec of any amp and can sound glorious in the right set-up. I spoke about topology….its amplifier is unique….class A for voltage and Class D for current. Its ability to produce GOBs of power in an instant and into low impedances is second to non and this is exactly what the Extrema needs. The Devialet frequency response deviates very little from the ideal, especially the upper frequencies, which are lightening fast and hugely energetic, without sounding in the least bit unnatural, hard or edgy. Again, this is exactly what the Extreme needs to get the best out of its soft dome Esotar tweeter and unique crossover (inductor in parallel instead of the usual in–series capacitor). Versus the latest speakers and drivers, the Extrema will benefit from amps that offer plenty of PR&T (pace, rhythm and timing), so again a Devialet strongpoint.
Given there’s close to 25 years between my hearing Extremas and Devialets, I may be completely wrong, but instinct tells me they could be an almost ideal match, given that the Devialet’s strong points and the Extremas‘ critical requirements are pretty much the same…..both ’iron fists in velvet gloves’.
I owned the Devialet special edition Original d'Atelier monos (the core is essentially the same as the current Devialet 1000 monos) for four years, driving the second generation TAD CR1 Mk IIs. Yes, in many ways, good, but four years and my current system (the TAD M700 monos driving the third generation TAD CR1 TXs) have shown me that the Devialets are not as good as they look on paper. Edgy with classical music, and the bass (while superficially impressive, especially with the SAM (speaker active matching) system) doesn't have the real massive current behind it (like the TADs produce). There's no subsitute for cubic inches and V12s. The Devialets are like cheap little four cylinder engines with a turbo stuck on them. I'd take a Ferrari V-12 any day by way of comparison. The Extremas, like the TADs, need true bi-wiring (two single wired pairs in shotgun mode) to really perform (not to speak of bi-amping). Good luck trying to bi-wire with the Devialet and and their cheap single pair plastic speaker posts, you'll end up cursing the day you were born.Here’s a suggestion from left field! Years ago I owned a beautiful pair of Extremas and powered them with BAT Vk500 monoblocks. Sounded wonderful. You may still be able to pick up a pair of the VK500s but if not already done, they’d certainly need a thorough service and all their capacitors replaced. If I were setting up a pair of Extremas today, the first amp i would audition would be Devialet….either the 440 monos or the 1000 monos. Its French and like a lot of designs from that country, uses an unusual topology. Firstly its a ‘one box’ unit with DAC, Preamp and amp. It has by far the lowest distortion spec of any amp and can sound glorious in the right set-up. I spoke about topology….its amplifier is unique….class A for voltage and Class D for current. Its ability to produce GOBs of power in an instant and into low impedances is second to non and this is exactly what the Extrema needs. The Devialet frequency response deviates very little from the ideal, especially the upper frequencies, which are lightening fast and hugely energetic, without sounding in the least bit unnatural, hard or edgy. Again, this is exactly what the Extreme needs to get the best out of its soft dome Esotar tweeter and unique crossover (inductor in parallel instead of the usual in–series capacitor). Versus the latest speakers and drivers, the Extrema will benefit from amps that offer plenty of PR&T (pace, rhythm and timing), so again a Devialet strongpoint.
Hmmmm, sound like you could have used a little help with getting your system set-up closer to perfect. The Devialets are incredibly transparent and will play exactly what they’re fed. I do however agree that spending 2 or 3 times the amount will, generally speaking, get even better results. There’;s no doubt that TAD M700s will do a bang-up job of driving the Extremas, but looked at the other way, I’m not sure a pair of Extremas are what you need for the M700s?I owned the Devialet special edition Original d'Atelier monos (the core is essentially the same as the current Devialet 1000 monos) for four years, driving the second generation TAD CR1 Mk IIs. Yes, in many ways, good, but four years and my current system (the TAD M700 monos driving the third generation TAD CR1 TXs) have shown me that the Devialets are not as good as they look on paper. Edgy with classical music, and the bass (while superficially impressive, especially with the SAM (speaker active matching) system) doesn't have the real massive current behind it (like the TADs produce). There's no subsitute for cubic inches and V12s. The Devialets are like cheap little four cylinder engines with a turbo stuck on them. I'd take a Ferrari V-12 any day by way of comparison. The Extremas, like the TADs, need true bi-wiring (two single wired pairs in shotgun mode) to really perform (not to speak of bi-amping). Good luck trying to bi-wire with the Devialet and and their cheap single pair plastic speaker posts, you'll end up cursing the day you were born.
Hi Raker,Regarding the Devialets, when I owned them, I fed them with an Esoteric K-01X (the previous generation) SACD player used as a transport, digital out with Wireworld Platinum 8 AES/EBU digital cable. Good on jazz and popular music, grated on classical music. Getting much better results with the Taiko SGM Extreme into Nagra DAC & preamp into TAD M700 monos driving the latest TAD CR1 TXs. Fantastic on jazz, popular, and classical music. No comparison by any stretch of the imagination, at least in my respective systems (Devialet in Tokyo and Taiko/Nagra/TAD in Singapore).
You may be pleasantly surprised with the Aleph 0 monos if you don't play at head banging levels... I never drove my Extrema with them but I did hear them with the original Electa Amators (which I bought on the spot and so began my Sonus Faber path...) and was startled by the match.Raker, thanks so much for all of the insight. I appreciate it. When the Extremas arrive I’ll listen to them with the amps I have and perhaps demo one of the amps you recommend for comparison’s sake. Right now my amplifier options at home are MasterSound PF100’s, Pass Labs Aleph 0 monoblocks and a Purifi 200 wpc amp just to see what all the excitement is about with this new design.
