Power Conditioning Advice
Pb Blimp
518
25
140
USA
Thanks.
I am reading an old thread which compares Torus (balanced in) to Equi=tech (balanced out).
I am trying to understand if the non-wall mounted units are close to the wall mounted ones.
Read the technology section of the Torus web site to understand this best. It depends on the unit. The important thing IMO (after the technology used) is sizing the transformer with significant available instantaneous current which involves using a multiple (4 or 5 times) of the "Rated Current" required by system components. Many people use the Rated Current and squash dynamics. If you are indeed not going to run your amps then a non-wall mounted unit should work well.
Pb Blimp
518
25
140
USA
The more I research the more options I am finding:
1 - Balanced in (Torus) vs.
2 - Balanced out (Equi=tech)
3 - Wall Panel
4 - Shelf unit
This is just supposed to be for my sources and pre-amp. I didn't plan on doing anything for my amps but I guess if I get a wall unit it would supply power to my amps too.
If you really want a step up in performance that's it.........dynamics, low noise floor et. al.
dminches
3,480
2,858
1,410
Thanks for the tip.
I noticed that some non-wall mounted units take 120V in and some take 240V in. I would assume that the 120V in is not balanced in and thus I wonder if it does as much as the others. I need to research this.
dminches
3,480
2,858
1,410
My amps have some power conditioning built in. I need to understand what works with them.
Folsom
6,030
1,503
550
Eastern WA
3 - Wall Panel
4 - Shelf unit
Seriously try a SurgeX from eBay. If it really floats your boat then get a modded one from ZenWave. At worst you have a better surge device for your TV. (the SurgeX never goes bad unlike the average little power strip "protector")
SurgeX engineers > any transformer device engineer I've seen
kleinbje
181
24
923
CT
Wow, please don't upgrade until you try a HZ. The difference between the mongoose and HZ is tremendous. I have hz on all my components. They X series are made by CH acoustic which was the company Dan tagged to make the HZ cable. Consider the HZ a X15. Run don't walk! I just saw you use tubes too, you will be very pleased.
Pb Blimp
518
25
140
USA
If you consider a wall mount remember the benefits go well beyond cleaning up the power. Your whole system has a new power supply with massive excess current reserves to instantly recharge each units power supply and capacitance with instant current to improve leading edge transients, dynamics etc. Depending on the complexity of what you listen to, the volume you listen to and your speaker/amp impedance match this can be a very big deal. People will watch the amp meter on their amps and claim the amp never draws more than say 20% of the rated power so how can a large transformer help? This is a very wrong interpretation. The instant current draw-downs that impact dynamics happen far faster than the resolution of these meters.
16,219
13,683
2,665
. . . The instant current draw-downs that impact dynamics happen far faster than the resolution of these meters.
This is a very good and interesting point.
I was afraid to go the whole Torus wall mount unit route out of concern about crimping dynamics of the amplifiers. But I am definitely getting an overkill current capacity Torus AVR60BAL for everything other than the amplifiers. I had a 240VAC circuit wired over to the equipment room for this express purpose.
The AVR60BAL has three 20 amp sections which I intend to utilize: one for the tape deck and turntable motor drive, one for the "left" pair of Aesthetix power supplies and one for the "right" pair of Aesthetix power supplies.
Folsom
6,030
1,503
550
Eastern WA
A transformer is not a capacitor. It can help keep voltage up during high use a little when you go from 240v to 120v. As the Torus site says they are able to maintain +/- 5v. There are some minor benefits to a slightlier friendly impedance, but they are small. The big benefit is the noise isolation, which is why they call them isolation transformers, not "power reserves". There is no such "reserve". And a lot of problems that can affect delivery of power may shift, some improving others getting worse (240-120 better than 120-120).
That is my nicer way of saying what I want to make clear, your statements are not true. And subjectively I have found transformer based systems to suffer from either slightly duller or harsher edges (as opposed to sounding "right").
BlueFox
1,709
407
405
What is sounding “right”, and what makes it “right”?
Pb Blimp
518
25
140
USA
So a 10 amp transformer is going to deliver the same instantaneous current to a system as a 100 amp transformer? Well that's interesting.
The use of a significantly over-sized transformer in relation to the size of the system's rated power requirements provides instant current when it's needed (like a capacitor would in a circuit). Of course a transformer is not a capacitor. My statement was meant to be what people call an analogy. (An oversized transformer has excess available power. It's really not that complicated.) Have you ever even used a properly sized transformer using the design standards recommended by a company like Torus to accomplish higher instantaneous current? Your comments read like someone accustomed to transformers used in a component's design not in power systems which weighs 220 lbs with virtually nil output impedance where units can be hundred-of-amps per microsecond.
After you chat with the guys at Torus look at what Caelin Gabriel says about the significance of instantaneous current and the measurement units for amps per time involved. Oh and by the way, thanks for telling me I am a lier "the nicer way." You are quite the guy.
Folsom
6,030
1,503
550
Eastern WA
I never said anything about using an undersized transformer.
Maybe you missed it, I specifically stated what I thought about transformer based systems - which includes wall, rackmount, and footers. My comments are specific to the AC system, not components.
Why would I chat with the guys at Torus, if you're saying I'm too poor or something? I'm not positive about what your "accustomed" comment means. And while I think Caelin Gabriel is a really nice guy that I appreciate, I cannot say I would consider him a source for AC systems information.
Back to transformers for a second. The reason the transformers are sized large isn't for the speed of current. The problem is that as the load increases on the secondary side (current needed) then the transformer starts to sag (voltage). Sag is a problem of winding resistance and/or heat. The winding resistance multiplied by the current, is the amount of sag; and heat can increase resistance. If sag is occurring beyond the threshold of what equipment needs, it'll be very audible (especially at heightened passages). Also if the transformer is producing heat then it'll shorten the lifespan & increase resistance. So clearly having a big transformer is a better way to keep heat down with a larger area, and resistance down with larger wire.
However if you're worried about the propagation speed of electricity, transformers are not ideal. The insulation on conductors is what slows down propagation (probably why we like teflon or cotton in general for interconnects). Transformers have A LOT of insulation around all the wire in them. I wouldn't worry about it, just saying it isn't ideal for "instant".
A real problem is what the complex impedance looks like. Current speed isn't the issue, it's what the current response looks like because of problems within the AC ecosystem. That's a complex subject, but as I've been saying transformers are good and bad in that respect, mostly neutral is a decent verdict. Larger ones sometimes can help subvert some issues.
Lastly, I don't think you're a liar, Paul. A liar is someone intentionally telling something they know not to be true. As far as you know what you're saying you believe to be true, but it hasn't been so I'd like to help fill in some corrections because incorrect information is not good for people wandering around with dollars in their hand. And I don't like to come off with "you're wrong" and then that's it - which is popular on the net. That's all I meant about trying to be nice.
Pb Blimp
518
25
140
USA
So let me get this straight. I make the point that an oversized transformer will improve transients, dynamics etc by making sure components have instantaneous current as needed during high volume, complex passages so the system's components power supplies are not starved and capacitors are charged. You in turn call me a liar (untruthful....whatever). You then spend multiple posts pointing out the positive effects of an oversized transformer when current demands are high but you continue to double down that I am not truthful.
Folsom, I am going to continue to restrain from saying to you the things I think about your knowledge and character. What I would like to request is that you stop engaging with me on this Forum.
Folsom
6,030
1,503
550
Eastern WA
You're welcome to press the ignore button on me, Paul. But I shall otherwise continue to post as I have been. Perhaps if you don't ignore me you'll begin to change your opinion because I certainly am not known for "character" problems.
Large transformers help maintain already available current. The Torus is somewhat unique in that it actually helps regulate voltage. Neither of these things have anything to do with "instant" or creating more "reserves". You don't buy a transformer to increase current or deliver anything "faster". That is just not how they work. I'm sorry if my explanations were not well enough into layman's terms to make it clear.
I simply feel it is bad, and incorrect to try and persuade people into believing transformers do something that they do not. They call them isolation transformers, or balanced transformers for a reason - as opposed to electromagnetic current enhancer or something. Anyways, they have their virtues, but they are not as you portray them with gaining current capability or "speed". Again I don't think you're lying or being "untruthful", but merely that you've been similarly led astray on what transformers do.
Let me illustrate an interesting point about current. You could pass 100A through a 34ga wire, about the size of a thick hair or so. Technically the electrons would move faster within the wire. The reason no one is doing this is because the heat will fry the wire (fast movement=heat). If you could keep the wire cool, it would be fine. The current is just as instantaneous as a larger wire using the same dialectic. The voltage would be much less through the 34ga wire if it were not cooled enough. And we're back again to maintaining voltage concerns, not current.
dminches
3,480
2,858
1,410
I spoke to tech / sales support at Torus Power. The gentleman was very informative and helped me start to figure out which unit was right for me. He claimed that there isn’t any difference between the rack mount and wall mount units. They both do the same job.
Now I have to further understand what exactly the unit does and if it is right for me. I am leaning towards the wall mount unit so it supplies power to my entire room. Right now I have have 2 dedicated 20 amp lines for all the equipment. So, I would only need the 45 BAL or 60 BAL. Each would give me a little expansion room.
opus112
462
4
148
Zhejiang
You should check out 'electromigration' - here's a link you might find useful : https://www.eetimes.com/document.asp?doc_id=1275855
A 34awg wire has about 0.02mm^2 cross-section so by my calculations that's a current density of half a mega-amp per cm^2. Its in the region where electromigration effects can't normally be neglected according to the article I linked.
rockitman
7,097
414
1,210
Northern NY
I'm loving my Torus RM 15 Plus isolation transformers (1 for each mono). My Pass amps sound better with them and have more instant current than plugging them straight into the wall. The amps really came alive. I am using PS AUDIO P5 regenerators for source. I would like to try a torus on the source too at some point to compare with the PS Audio.
dminches
3,480
2,858
1,410
Right now I am leaning towards getting a Torus wall mount unit to supply power to the entire room. I think I will get the WM 60 Bal AVR.
Pb Blimp
518
25
140
USA
You are going to be very happy.
dminches
3,480
2,858
1,410
